R1100S Rear brakes: inner pad question
I just replaced my rear tire and went to put the wheel on I noticed there’s no piston on the inside of the rotor, just a pad sitting there. And my pad almost fell out. It’s on retained by the pin at the back. There appears to be no support the the pad on the inside front of the calliper. You just place it into the body and hope it stays?
Don’t want to ride it until I’m sure it’s installed correct. |
![]() Are there any pistons on either side?
2004 R1100S |
Registered Agitator
With how well they work must be something in there. I can pretty much slide the rear at will. Good thing the fronts are hand controlled 'cause my foot has all the delicacy of a sledge hammer.
To answer the initial question, if I remember right the tabs at the back lock or more like position the pads in place inside the caliper to keep them from falling out when mounted. I am however too lazy to go look to confirm my feeble failing memory. |
There is the pin from the back, and the spring thing #7 that pushes down on the pads to keep them from rattling or squeaking.
2001 RS1100S Light. Black on Black w/carbon fiber bits. |
The brake pad that does not have a piston pressed against it, sits on a ledge or two ledges.
Come to think about it, both pads sit on a ledge or two. The 2004 R1100S brake caliper might be different than your year brake caliper.
2004 R1100S Last edited by Groceryrun; 04-30-2020 at 06:36 PM.. |
Well went out for a ride and everything seems fine. Besides how much rear brake do you really need?
Google "single piston caliper."
Lots to learn.
Kent Christensen Albuquerque '12 R1200RT, '02 R1100S '01 Boxster |
