Been Nowhere Done Nothing
Battery Tender
Stupid question probably but I never used the BMW electrical socket to hook up a Battery Tender. I just bought another S and the guy included a Battery Tender with the BMW male end on it, the bike has a female socket and goes up to the wiring loom under the seat.
I use Battery Tenders on all my other bikes but have the Battery Tender supplied pigtail directly connected to the Battery. It's a small two terminal connection/plug-in with a fuse.
05 R1100S BCR, 04 R1150R 16 S1000XR, 24 S1000RR, 21 Ducati 950S |
Registered Agitator
It doesn't matter which you use they do the same thing, charge the battery. I have both on mine because I forgot the plug on a trip & didn't have a way to charge my dead battery so I installed the 2 pin tender line also.
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
On the R1100S bikes, the Battery Tender will work either way. Direct to battery, or through the power outlet.
With the R1200S, the CANbus is trickier. So, on my R1200S I have the little Battery Tender pigtail connected directly to the battery. Otherwise, you need the BMW specific version to plug into the power outlet.
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
What happens under the seat? Where does it go from there
My socket on the left side of the bike was wired in under the seat. the main wiring loom under the seat had a wire connector and my socket wiring was connected into it. I've actually removed my socket from the bike. It's a female connector with a brown wire and a red/white wire.
Registered Agitator
No idea who or what motopump is but he's wrong. I can't imagine what you'd be plugging into it but that amperage is pretty high. People have been using that plug for all kinds of things from phone charging to heated suits for ages with zero problems. As for where the wires go strip it down & see, but they go to the battery however they're routed. It's always hot not switched. If you feel the need for a fuse just splice it inline on the positive line to the socket.
unsafe at any speed
The Accessory plug has a fuse, Been awhile since I messed with mine, but if i am not mistaken it also powers the clock.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
yes on the diagram it is fused with the clock, 15Amp.
