-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/forumdisplay.php?f=24)
-   -   Click.....nothing (http://forums.pelicanparts.com/showthread.php?t=1098712)
varmint 07-27-2021 04:57 PM
Click.....nothing
Number Seven started fine this morning. Rode into town, got mail. Came out and click....nothing. No fuel pump whirr. No starter noise. No lights.
Trailered her home. On a charger now. Green light indicates charged, right? Faint buzz when I turn the key. Am going to wait a few hours and try again. Instrument light on. Green neutral light shows. And kickstand up. So it’s not one of the safety lockouts ****ing with me.
Battery is a year old. Was on a trickle charger over winter. Has been starting without incident the last two months.
What else should I be looking at?
varmint 07-27-2021 05:00 PM
Haven’t ridden in about a week, rain. Battery charger light shows steady green. That tells me fully charged. But the bike acts like the thing is near dead. If the battery is cooked it’s a strange way to die.
http://forums.pelicanparts.com/uploa...1627433979.jpg
wswartzwel 07-27-2021 05:43 PM
Corroded battery cable end? could be loose at the starter or the ground strap to the engine.
varmint 07-27-2021 05:51 PM
Fair guess. The ground strap sounds interesting. I get no fuel pump whirr either. Trying to figure a common denominator.
Now when I turn the key I get a low buzz.
Have Thursday off. Going to dig into it then.
ckcarr 07-27-2021 08:05 PM
Green light on a Battery Tender doesn't mean a good battery sadly enough.
Happened to me long ago, as the bike was on my Tender, lights green, go for a ride and same thing. stuck in the middle of nowhere...
Not saying buy a battery since you say it's newish, but it's possible that it has good voltage, but no power. If you could hook in a multi-meter somewhere, then observe the voltage when attempting to crank... If it immediately drops way down, there's a problem.
varmint 07-27-2021 09:00 PM
Because the battery is so easy to get to,
I’m gonna take it out Thursday and have the local auto parts store test it. A new one is expensive. But it would be a relief that it’s not something more complicated.
Swamper 07-28-2021 06:14 AM
Expense is relative when your stuck out with no help. Batteries are best a two year rental.
sgoodwin 07-28-2021 08:06 AM
If you replace the battery go lithium, you'll appreciate how it spins the motor over so much faster not to mention major weight savings up high.
Chris Canning 07-28-2021 08:46 AM
You beat me too it...who the hell fits lead acid...it’s 2021 :D
wswartzwel 07-28-2021 08:47 AM
How do lithium batteries do in cold climates, like "secure undisclosed locationville"?
sgoodwin 07-28-2021 09:34 AM
From what I read you need to wake them first by say turning on lights, which with most bikes isn't a problem as you can't turn them off anyway, but what do I know, 60 degrees is cold here.
Chris Canning 07-28-2021 10:14 AM
I have a bike that has had a lithium battery for over 7 years...only ever had one glitch...fitted an aftermarket Reg/Rec on a bike that didn’t like lithium and the supplier very quickly put a red letter warning on the site, never had a problem with OE Kit.
Even have lithium on a 1290 KTM turns it over like a good’un.
varmint 07-29-2021 02:15 PM
The battery is dead. Deader than dead.
Ordering a new one today. Probably won’t be able to pick it up for two weeks.
sgoodwin 07-29-2021 02:54 PM
Try this, I have 2 of these now. Their older one without the over/under charge circuits lasted 6-7 years before crapping out. These come with the Tender cord with the reset button built in. It gives you two ways to hook up a charger if you already have the BMW outlet. They weigh next to nothing & I simply use my standard Tenders with no problems. They come with a pile of stick on foam pads to fit them in your battery box. I highly recommend them.
www.ebay.com/itm/202968319079
cured!
varmint 07-29-2021 03:08 PM
Does not ship to Alaska.
I’ll be up an anchorage in a couple weeks anyway. Trying to think of anything else I need while there.
sgoodwin 07-29-2021 04:11 PM
Well bummers. I can't believe how long that link was.
ckcarr 07-29-2021 07:42 PM
I still go with the PC680 Odyssey.
It's heavy, but gives you good traction...
BikerMiker 07-30-2021 04:23 AM
I use this now: https://antigravitybatteries.com/
Chris Canning 07-30-2021 07:15 AM
https://www.ebay.com/itm/202968319079?epid=252104310&_trkparms=ispr%3D1&has h=item2f41dac467:g:bxcAAOSw1tVemiNz&amdata=enc%3AA QAGAAACoPYe5NmHp%252B2JMhMi7yxGiTJkPrKr5t53CooMSQt 2orsSjVt3vLKCbov98Z19qhuwY9WmuIOuKg8kmqIW9fnpexPb2 HfJqxuPCnNLqSTcEQmcgR2Y1FjX8fIPASXzHX86OpOuug8enEd VHQHm05lEA8Mte38yAtCKwbWAhezZRVUMgyl2rniB4L26zaBZC 84PFZ1fESisWDyQ5BUBMgMmtJU1PGuQBwm1zmssY3nIjdVcMu8 NFQgn5NfiDey3WhyzRssNcuoQE1UbPFq1wo%252FZruqilpvNE HBPVbH1aVM0c9avbcWas%252Fge0fiiS0w6Y%252B7LIZu3kr% 252FV0q7MoC3a%252FYbWaGxE%252FcszwrutCLPOXxuFPeZ7d POcFYSw1%252FtqqDd9gA4tY6DIfFHNGm84owTpOBm36SgDRmA OUR7FGBT6H0DYcPgzIVodXuLJDSr4uZJG9Fpt6lMRfGhKZVpa7 qjgVVlO6aRoGwNkmmznhGoGRoK%252FN7g%252F6y9j0E6TlYz v3EsgJ%252BoZuOXR7%252BGA%252FdweYkcobs1w6cWLfYBhw cnjUZsAA%252BNqBTXb4RLw4Fy2aAZPE9eOmV4U6qXp7kEec0B hyTFeRdBGwM1cjSsLW1jeaQGFXUNWfYUTft52hKgzutpv30q1d 2qkmHwXGaVscVMCYbYeFmVL%252BfhviMgp1%252FEdaEQnpj8 %252B3MdgBWlAZLH5i%252BKSTuaew2TQ72xM351G3hQXHgAOe gQivSM8uSD9OPNKk%252FwViK2T5DvSFj9rh0LrFu3A7P63Dua qPnC8gNs9mqODqBDNHlBArVCGjW1J5Lbx0KJHJezmltiQvWgGs tCUgPvF41AfrR%252FRQr5Z8Ch6jJPYk0x9%252FdS2cGgZbef KLL%252F3%252FtdR9V4776ynYmbSsjHbhH%252B%252FZSb4y %252BLg0Q%253D%253D%7Campid%3APL_CLK%7Cclp%3A23345 24
Jeez that’s one big lithium battery 😳
sgoodwin 07-30-2021 08:27 AM
Larger than their original but about 2/3 or less that the stocker & many times lighter.
