I reckon so. I just didn't know what, if anything I was risking by having too much of a good thing. Anyway, a good day-long, "spirited" run into West (bg) Virgina and back pretty much takes care of any excess oil lurking around in the engine.
![]() --Jim
--Jim 2002 M3, 6MT 2009 Element 2022 Model Y |
Stuff like: #1. Rubber side down; shiny side up? As a relative newbie to this bike it sounds like there are quite a few rules that would be good to know.
2004 R1100SA Pacific Blue 2000 323i Steel Grey |
Used to ride a motorcycle
You think we just freely hand information like that out to newbies? This isn't the Library of Congress Seth. You'll get more rules when we decide you're ready for them.
'01 BMW R1100S | '03 Suzuki SV650 #555 "Princess" | '07 Suzuki SV650 #555 "Pigpen" | '16 BMW G650GS Last edited by JustAnotherSquid; 01-20-2004 at 08:42 AM.. |
Edministrator
I've heard later models drain oil to read in the sight glass better than previously. Anybody know when that change took place?
Good post? Leave a tip! O - $1 O - $2 O - $3 |
No Info on (t)his member
>Originally posted by JustAnotherSquid
>Oilhead rule #31: Never fill the oil past >half-way on the sight glass Mostly the benefit of 'red dot' oil level, is to reduce the amount of blow by that coats the inside of our airboxes. Haven't noticed the oil light glowing, even during extended 5k - 7k running ( it is however, possible that it did light up, but I'm sure I was busy doing something important during those times ). :D Anyway, middle o' the sight glass it is! jeff a clean airbox is a, well, umm, a clean airbox
_________________________ jeff clark 99 R1100S 82 Alfa Romeo Spider Veloce Last edited by jclark; 01-20-2004 at 07:41 PM.. |
Regards, Ian 03' R1100S |
Oil Level
As a relatively new S pilot I must admit I find the oil level nothing short of astounding in it's fluctuation, though the cooler pr valve would explain some of that :-) Having always ridden Jap machines the boxer is certainly proving, ahem, interesting, good news being that I've finished the rebuild, clutch, heads, seals, exhaust, blah blah blah.
Seth, what's tha paint code under your seat for your bike as I really really like that colour, I know it's pacific metallic blue, but don't know the code ? Thanks PAul Keep it sticky side down
Cheers PAul On a clear disk you can seek forever |
Thanks Sea Dog.
I'll check the paint code this evening after work and let you know. The color is one of the first things that I noticed when I first saw the bike at the dealer. To me the S is already a very attractive bike just because of its shape, but then to finish it in a color like this just puts it over the top. I have definitely been enjoying it ever since.
But I like your reasoning better. Sounds more technical.
'01 BMW R1100S | '03 Suzuki SV650 #555 "Princess" | '07 Suzuki SV650 #555 "Pigpen" | '16 BMW G650GS |
Sea dog.
As the stones once said,PAINT IT BLACK! gus |
Paint it Black
as opposed to completely CF with MAraDone Cheecky chesni wheels in gold !!!!
It does look good in black, but I really really like that Blue...... Cheers PAul Keep it sticky side down.
Hairy Muff!
gus |
Muff
Helps keep off the cold ...
Come to think of it that's Chris's bike isn't it, and the wheels are probably the only bloody ones that I didn't mention Dymags( with avengance ) Cheers PAul
Yep.But i dont mind people mistaking it for mine.SAves me a fortune in bits!
gus ps mines a jaffa. |
Sea dog.
As promised, I had a look and the paint color is: 744 At least that's what is says on the little sticker under the seat near the tire plug kit. If that isn't the right sort of number, let me know and I'll have another look. Regards, Seth
Hi Seth,
I suspect that's it, thanks very much, it's appreciated, all the best. Cheers Paul Keep it sticky side down.
/quote
I was thinking simpler than that - it's safer to fill to the middle of the sight glass to prevent overfilling should there be oil trapped up in the cooler. The bike doesn't need the oil level right at the top of the red circle, and doing so just risks overfilling the engine. But I like your reasoning better. Sounds more technical. /unquote Um, well, I think the idea is that one doesn't accept the veracity of the sight glass, without first being *sure* that the engine has been thoroughly temperature cycled ( determined by feel - the oil cooler is just as hot on the sight window side [ right hand side looking at the headlight ] just touch the bottom of it - if you can't touch it for more than a second, your prolly all right. Then park it on it’s side right away for, oh, 10 minutes or so, put it on the center stand, and look at it in the morning. If you look at it after only 10 minutes on the center stand, the value will be off by the amount of air mixed in with the oil - after an overnight ( well prolly sooner, but that’s not where I’m headed ) sit it will all be settled out. And reasonably accurate. jeff ...my finger hurts.... |
k.
_________________________ jeff clark 99 R1100S 82 Alfa Romeo Spider Veloce |
