I reckon so. I just didn't know what, if anything I was risking by having too much of a good thing. Anyway, a good day-long, "spirited" run into West (bg) Virgina and back pretty much takes care of any excess oil lurking around in the engine.
--Jim
--Jim
2002 M3, 6MT
2009 Element
2022 Model Y
Old 01-20-2004, 06:41 AM
SethK's Avatar
Originally posted by JustAnotherSquid
Oilhead rule #31: Never fill the oil past half-way on the sight glass.
So what are rules 1-30 and 32-n?
Stuff like:
#1. Rubber side down; shiny side up?
As a relative newbie to this bike it sounds like there are quite a few rules that would be good to know.
2004 R1100SA Pacific Blue
2000 323i Steel Grey
Old 01-20-2004, 08:29 AM
Used to ride a motorcycle
JustAnotherSquid's Avatar
You think we just freely hand information like that out to newbies? This isn't the Library of Congress Seth. You'll get more rules when we decide you're ready for them.
'01 BMW R1100S | '03 Suzuki SV650 #555 "Princess" | '07 Suzuki SV650 #555 "Pigpen" | '16 BMW G650GS
Old 01-20-2004, 08:38 AM
Edministrator
Steve Carlton's Avatar
I've heard later models drain oil to read in the sight glass better than previously. Anybody know when that change took place?
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 01-20-2004, 10:59 AM
No Info on (t)his member
jclark's Avatar
>Oilhead rule #31: Never fill the oil past >half-way on the sight glass
Mostly the benefit of 'red dot' oil level, is to reduce the amount of blow by that coats the inside of our airboxes.
Haven't noticed the oil light glowing, even during extended 5k - 7k running ( it is however, possible that it did light up, but I'm sure I was busy doing something important during those times ).
:D
Anyway, middle o' the sight glass it is!
jeff
a clean airbox is a, well, umm, a clean airbox
_________________________
jeff clark
99 R1100S
82 Alfa Romeo Spider Veloce
Old 01-20-2004, 07:38 PM
Originally posted by shoemakj
Makes sense to me, but then why does my dealer insist on filling to the top of the sight glass (or higher) when viewed from the center stand?
The owners manual & others have said that overfilling is bad, but what kind of damage are we talking about here?
--Jim
My dealer does this as well Is there any way to syringe off some oil without using the drain bolt? I am thinking about long tube via the oil filler hole.
Regards, Ian
03' R1100S
Old 01-21-2004, 08:20 AM
The Sea Dog's Avatar
Oil Level
As a relatively new S pilot I must admit I find the oil level nothing short of astounding in it's fluctuation, though the cooler pr valve would explain some of that :-) Having always ridden Jap machines the boxer is certainly proving, ahem, interesting, good news being that I've finished the rebuild, clutch, heads, seals, exhaust, blah blah blah.
Seth, what's tha paint code under your seat for your bike as I really really like that colour, I know it's pacific metallic blue, but don't know the code ?
PAul
Keep it sticky side down
Cheers
PAul
On a clear disk you can seek forever
Old 01-21-2004, 08:41 AM
SethK's Avatar
Thanks Sea Dog.
I'll check the paint code this evening after work and let you know.
The color is one of the first things that I noticed when I first saw the bike at the dealer. To me the S is already a very attractive bike just because of its shape, but then to finish it in a color like this just puts it over the top. I have definitely been enjoying it ever since.
Old 01-22-2004, 08:01 AM
I was thinking simpler than that - it's safer to fill to the middle of the sight glass to prevent overfilling should there be oil trapped up in the cooler. The bike doesn't need the oil level right at the top of the red circle, and doing so just risks over-filling the engine.
But I like your reasoning better. Sounds more technical.
Old 01-22-2004, 08:06 AM
GUS GUS is offline
Sea dog.
As the stones once said,PAINT IT BLACK!
gus
Old 01-22-2004, 08:31 AM
Paint it Black
as opposed to completely CF with MAraDone Cheecky chesni wheels in gold !!!!
It does look good in black, but I really really like that Blue......
Cheers
PAul
Keep it sticky side down.
Cheers
PAul
Old 01-22-2004, 08:51 AM
GUS GUS is offline
Hairy Muff!
gus
Old 01-22-2004, 09:14 AM
Muff
Helps keep off the cold ...
Come to think of it that's Chris's bike isn't it, and the wheels are probably the only bloody ones that I didn't mention Dymags( with avengance )
Cheers
PAul
Cheers
PAul
Old 01-22-2004, 09:33 AM
GUS GUS is offline
Yep.But i dont mind people mistaking it for mine.SAves me a fortune in bits!
gus
ps mines a jaffa.
Old 01-22-2004, 12:37 PM
SethK's Avatar
Sea dog.
As promised, I had a look and the paint color is: 744
At least that's what is says on the little sticker under the seat near the tire plug kit.
If that isn't the right sort of number, let me know and I'll have another look.
Regards,
Seth
Old 01-22-2004, 03:43 PM
Hi Seth,
I suspect that's it, thanks very much, it's appreciated, all the best.
Cheers
Paul
Cheers
PAul
Old 01-22-2004, 05:20 PM
jclark's Avatar
/quote
I was thinking simpler than that - it's safer to fill to the middle of the sight glass to prevent overfilling should there be oil trapped up in the cooler. The bike doesn't need the oil level right at the top of the red circle, and doing so just risks overfilling the engine.
/unquote
Um, well, I think the idea is that one doesn't accept the veracity of the sight glass, without first being *sure* that the engine has been thoroughly temperature cycled ( determined by feel - the oil cooler is just as hot on the sight window side [ right hand side looking at the headlight ] just touch the bottom of it - if you can't touch it for more than a second, your prolly all right.
Then park it on it’s side right away for, oh, 10 minutes or so, put it on the center stand, and look at it in the morning. If you look at it after only 10 minutes on the center stand, the value will be off by the amount of air mixed in with the oil - after an overnight ( well prolly sooner, but that’s not where I’m headed ) sit it will all be settled out.
And reasonably accurate.
jeff
...my finger hurts....
Old 01-22-2004, 06:29 PM
Yeah, that's bascially my ritual after a long ride. Still don't get a consistent reading though.
Old 01-23-2004, 03:42 AM
jclark's Avatar
k.
jeff clark
99 R1100S
Old 01-23-2004, 08:05 PM
