bbq_duck's Avatar
Send a message via Yahoo to bbq_duck
and... my good buddy shannon got me a neck piece that you soak in water and wear under your jacket... some kinda silicone beads inside that hold the moisture providing a longer comfort experience.... havent had a chance to try it out yet, but i have seen his work
Cornfed - Easy Duckman, I know over two hundered ways to kill a man.
Sherry - You could glue an open jar of rats to his face, then blow torch the other side of the jar so the rats have to eat their way out through his face.
Cornfed - Two hundered one
2000 R1100SA
2004 FORD F350 4X4 DIESEL CREW
2000 JEEP CHEROKEE
1985 911 CARRERA TURBO-BODY
1985 HONDA XL600R
Old 04-26-2004, 04:56 PM
steve abella's Avatar
thoose neck soakers work real well they use to make a vest made out of the same meaterial that worked but was a little heavy
,93 LT Hacked
98 RT
02 S ohlins/laser
06 HP2
84 GS/KTM
Old 04-26-2004, 05:34 PM
JoeM's Avatar
Neck soaker? I just googled it and didn't get any results steering me to a site that sells them. Any ideas on where I may find them in So. Cal? Thanks!
Old 04-26-2004, 09:49 PM
Dale Flowers's Avatar
I’ve one upped the wet tee shirt approach by modifying a camping towel, found at any camping supply store, with a slit and hole for your head. It holds a great deal of water and will keep you cool much longer than your shirt.
'99 R1100SA, ;06 DR650, '84 R100RT
Old 04-27-2004, 08:22 AM
John Lyon's Avatar
I got one of those "neck soakers" things at Big 5 sporting goods, of all places. Rode from LA to Phoenix across the dessert last June, and it really worked well. My jacket was a Belstaff Airflow, which has zippered vents on the arms, chest and back. I only wished my pants and boots had some vents too.
The neck thing stays wet for hours, unlike a soaked T-shirt (yuck). I also used a camelback, which is probably the most important thing of all. Its one thing to sweat a bit, quite another to get dehydrated.
Old 04-27-2004, 08:52 AM
John Lyon's Avatar
Sheez, I mean desert.
Old 04-27-2004, 08:55 AM
SethK's Avatar
If you want to go really over the top, you could try one of these ...
from
http://www.freshairsystems.com/cool.htm
As an added bonus, you could keep your lunch in the little cooler.
2004 R1100SA Pacific Blue
2000 323i Steel Grey
Old 04-27-2004, 11:57 AM
Helimot (in CA) sells something called a "cool shirt" that is a synthetic mesh w/ thick ribs. Creates a space between your leathers and you that allows sweat to evaporate. I wear one directly under my leathers in hot weather and with a regular tee over the cool shirt in cool/cold weather. Helps a lot in hot and in cold.
Old 04-27-2004, 12:21 PM
