R1100S seat cowl hardware
Hello, all, hoping someone can help get me sorted out here. I'm trying to retrofit my 1999's seat back to stock from a Corbin , which came with the bike. I got an '03 seat to fit the bike perfectly, but can't mount the seat cowl now. I understand there's a difference in hardware between early and later models, can anyone tell what I have from the pictures here? The pins are WAY too large in diameter to go into the socket. Thanks!
Socket in the seat ![]() socket removed ![]() The pin that is too big
The pin in the last photo looks correct to me (for stock). I know you can purchase (order) the pins from your dealer. They're only a few bucks each.
diz plaz is cwazy
You seem to have the older pins. The later type 2004 are screw type but with a very odd thread.
Life rewards action, He who is not afraid is safe! A Zest for living requires a willingness to die! -------------------------------------------------------- BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo) |
Registered Agitator
You can only get the newer style pins & socket from dealers unless you get lucky & they have old stock. I had to replace both when an old style pin fell out while riding. The new pins are metal not plastic and they lock in better.
I may have two '99 sockets; but, they are in NC and I'm not. If you can wait a while I'll check them out when i go back up.
Thank you, gentlemen. Since the seat is off an '03 and the cowl is '99, it appears I'll either need 2 old style sockets or 2 new style pins. I appreciate you identifying what I have, I almost ordered WAY too much stuff from Max
Misfit
N.
Nils Menten - Tucson, Arizona, USA* 2001 R1100S "Light", gone but not forgotten. http://tinyurl.com/zv3tpc5 I Do Vapor Blasting! Visit restocycle.com for information. Ikon shocks for your BMW! https://www.ikonshocksusa.com/ |
Happily Married
oh...'03From 5 years ago: Quote:
Garrett Topham 1999 R1100S Mandarin/Black- Öhlins, Motolights, Hyperlites, Spieglers, Corbin, Techlusion, Ztechnik muffs, Lennie's, Hornig plate bracket. Also available: '11 Sprint GT, '10 Thruxton, '09 G650GS, '07 F800S, '06 F650GS, '03 DL1000, '98 DR350SE, '97 RMX250, '82 R100S/RS, '79 TT500, '75 CB400F, '74 TL250, '71 CT90, '69 CB450 Last edited by BumbleBeemer36; 06-23-2011 at 10:04 AM.. |
Misfit
N.
Thanks, N.
I bought the newer style pins, problem solved
Anyone know a source for old style pins? I've just bought a cowl for my '00 (which never had one) and I'm pretty sure that I need a pair of old pins to fit it on.
Ideas?
R1100SA |
Gasteropod Rider
You may consider getting the entire new type of assembly as it seems that the older design had a tendency to let the cowl fly away. I don't know how much work the change is though.
Man it's flat out here!
Find part numbers for your BMW Car/Motorcycle here: RealOEM.com * Online BMW Parts Catalog
Key in the last seven of your VIN Serial Number for an exact match.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD |
Looks like A&S has the complete kit of two for about $40. Meh.
A&S BMW Motorcycles Microfiche
mechanicalhusbandry.com 1974 R90/6 1990 VFR750F 1999 R1100S |
Thanks guys, this is apparently just what I needed.
R1100SA |
Could anyone post a photo of the new-style pin and receptacle? TIA
Kent Christensen Albuquerque '12 R1200RT, '02 R1100S '01 Boxster |
