Future BMW WSP Racer
YellowRacer's Avatar
Removing the rear shock...
Do I really have to remove the exhaust to remove the rear shock on my 2001 BMW R1100S?
How do they do it?
Why do they do it?
Riding, and crashing, and riding, and winning.
and always faster, and faster, and faster - Faster
'01 BMW R1100S
Old 12-05-2009, 11:00 AM
Hey ya'll watch this
Hoots's Avatar
I had to loosen mine to fit the Öhlins.
Hoots
Midvale School for the Gifted
Class of 1990.
Old 12-05-2009, 11:05 AM
I don't want a pickle
bill pierce's Avatar
Yup, it's not hard though about 20 minutes and your done.
Old 12-05-2009, 11:25 AM
Regrepair site.
Hi guys,
Here is my link if anyone is intersted.
[url=spam[/url] is an advanced registry cleaner for Windows that can safely clean, repair and optimize your registry in a few simple mouse clicks.
With best regards,
Vopfoonsosy
Old 12-05-2009, 11:30 AM
so you have to clean the registry before removing the shock?
man, i missed that step entirely last time.
good to know!
is the registry that thingie next to the left fuse box?
'04 R1100s. I changed a couple o' things.
Old 12-05-2009, 12:00 PM
roger albert's Avatar
Only on bikes with ESA (or on HP2S/12Ss if you want to be able to adjust the idle)
I hope you add this to your suspension primer.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 12-05-2009, 12:51 PM
And back to reality. On a lot of R11S shock/exhaust combos, loosening the exhaust can be enough.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 12-05-2009, 12:52 PM
Uh....who me?
Bob Hancock's Avatar
I don't recall loosening my exhaust when I removed the shocks to send for rebuild.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 12-05-2009, 01:18 PM
Ok, thanks guys. I'll try it tomorrow sometime.
How do they do it?
Why do they do it?
'01 BMW R1100S
Old 12-05-2009, 04:47 PM
I didn't touch the exhaust on my 11S when I installed the Ohlins.
Old 12-05-2009, 06:05 PM
Living on borrowed time!
JonyRR's Avatar
BEFORE you remove the shock
Boot using your recovery floppy
type fdisk /mbr
press enter
go have several shots of Patron tequila
let me know (via email) how it went
thanks...
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 12-05-2009, 06:08 PM
jdlowery's Avatar
Depends which exhaust you have. If it's stock probably not. If it's Staintune, then you will need to loosen and move out the way.
Jim
'18, Ford F-150; '07, Lexus IS350; '01, R1100S; '80, R65; '76, Honda CB750 Four; '73, Ducati 750 GT; '70, VW Beetle; '65, BMW R60/2;
'64, Triumph Bonneville; '64, MV Agusta 125 GTL; '60, BSA Gold Star; '55, R25/3
Old 12-05-2009, 07:01 PM
Stock exhaust does not require removal to remove/install shocks. Shock manufacturer does not matter at all.
Some aftermarket exhausts- like Laser- require removal of Y-pipe to access lower shock mounting bolt. Some others do not. (it's all about the routing path of the up pipe)
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 12-06-2009, 06:57 AM
Can't recall which shock it was, but there was definitely one in my shop where I had to loosen exhaust to handle lower mounting bolt properly. No doubt about that. Just have to try and see what your combo requires. Staintune have been the toughest so far (though they're a darn good exhaust)
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 12-06-2009, 12:22 PM
Do not take too seriously
throttlemeister's Avatar
Yeah, Staintune is a b1tch when it comes to removing/installing the shock. I can't get enough space unless I remove the mufflers and up pipes, and it's a nasty job getting them installed and lined up properly again. Although I am properly more anal about how it is supposed to line up than the average dealer.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 12-06-2009, 01:31 PM
see, that strikes me as odd Roger, as the lower mounting point doesn't move with a new shock, and the stock up-pipe allows easy bolt clearance. are you sure those bikes were not running somebody's aftermarket pipes?
Old 12-06-2009, 01:39 PM
Hi, what bolts did you loosen ?
Old 10-08-2022, 10:28 AM
Which bolts did you loosen?
Old 10-08-2022, 11:10 AM
Jersey Boy In Texas
njsax's Avatar
It's the lower shock mount bolt that can be difficult to remove. With a factory exhaust you might not have to remove the exhaust or loosen anything, but that's me saying that BMW should have designed it that way. I've never had to do it myself because mine came with a Staintune system installed. When I replaced my shock, I had to remove that aftermarket exhaust.
It's not the exhaust so much as it's the taillight assembly, that takes up the time. If you do have to remove the exhaust, clean all the joints and use some neverseize paste when reassembling.
John Filak
Dallas, Texas
Old 10-08-2022, 03:31 PM
Send a message via AIM to tomvv11
With the stock exhaust I had enough room to unbolt the stock shock and fairly easily mount a YSS unit. Don't remember any particular frustrations. Likely used a couple 2x4s to apply lift to the rear wheel to get the lower bolt to line up, but it's been a few years.
Old 10-17-2022, 05:45 PM
