Two-items Valve stems & Center stand
Can any of my brethren help me with the following:
(1) The exact diameter of the valve stem opening in a stock R1100S Rim? I own a 2002 and would like to replace the current cracked stems with 90-degree stems.
(2) I am 60 yrs old, 69.5-inches and 180-pounds. I purchased my machine after years of wanting this particular model and after owning and riding a Vespa PX200 The immediate problem is it is very difficult for me to get the bike up on the center stand. It is an abject embarrassment and has subjected me to much derision from family and other riders. Any suggestions?
Thanx
Old 10-12-2009, 02:08 PM
turboflyer's Avatar
One might weld a short extension on to the center stand arm to give you more leverage. At the extreme end possibly the motorized RT stand could be retrofitted. Or one could just go to a regular detached stand like Pit Bull or make your own.
Old 10-12-2009, 02:26 PM
Uh....who me?
Bob Hancock's Avatar
It just may be your technique. Put your foot on the centerstand pad, right the bike and get the pad centered. Then lift a bit with one hand on the handlebar and the other on whatever you can grab at the rear (luggage rack is perfect if yours is fitted for system cases). Put your weight down solid on your foot that's on the pad. Give it a lift all together....it's kind of a timing thing. It should come up pretty easy. Your 180 lbs is plenty if you do it right unless you are physically impaired in some way. I can do it with my 210lbs but most of that is fat in my head.
I have valve stems that fit the bike but don't remember what size it is. The recess that fits into the wheel hole mics 15mm and it says "A TR 412" on the inside. Hope this helps.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 10-12-2009, 02:43 PM
Initials & assault rifle
cageyar's Avatar
I've showed riders smaller than you how to put a 750 lb. Honda Gold Wing on the center stand. Your issue is you are trying to lift the bike with your hand and back.
When you do it correctly, you are not lifting with your hand. Your leg is much stronger than your arm. The key is to place your foot on the center stand tab and drive straight down with your leg while lightly pulling the bike to the rear with your hands-one under the seat area and of course one with the handlebar. Most of the effort should be in your leg and very little lifting force in your hand-your hand should only be directing the bike. When done correctly, I can put a Gold Wing on the center stand with two fingers of my right hand. Push with your leg and direct with your hands-do not lift with your hands and back.
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER
1982 CBX | OLD SCHOOL
1969 H1 | QUESTIONABLE SANITY
Old 10-12-2009, 02:48 PM
two-items-valve-st
Thanks to turboflyer, Bob and cageyar. There is no doubt my technique is incorrect. I believe I will have my Son stand on the rightside to hold the bike up in case I lose it and I will simply practice!
Old 10-12-2009, 03:08 PM
cageyar's Avatar
Drive down with your leg-don't lift with your hand and the bike will pop right up on the stand.
Old 10-12-2009, 03:12 PM
What cageyar said, start with arms and back straight, leg bent. One hand on bars, one hand on lift point. Use leg muscles only, simply stand on the center stand with all your weight, then straighten leg. Easy as pie.
On my 04 stems are the 11.3mm size. I got them from here http://kurveygirl.com/shop/index.php?cPath=27.
If your rims have the rib that runs around the center and intersects the stem area, you will need to use a dremmel or similar tool to make a slot in the stem to fit. Caution, front ane rear ribs are different, and require different groves.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E.
Also residing in the barn my son's bikes:
'89 GS500ES, Ducati Monster 620 dark
Old 10-12-2009, 03:17 PM
moze229's Avatar
I concur with this statement by cageyar. I'm 6'1 and only 160 lbs. and I can do it easily. I was a little intimidated of the whole thing myself at first, but it's really easy once you do it. You're actually doing more pushing with your leg than you are lifting the bike.
What I do is get the bike on the sidestand first. Then standing next to the bike, hold it straight up and get the center stand down where it's simply touching the ground so you can tell where the bike is standing straight up. Once you got your foot down on the stand, you don't have to worry about the bike falling too much at that point since it's being held in check by the stand. Then push down with your leg on the stand while holding on to the bars with your left hand and grappling "underneath the seat" area of the bike with your left hand and slightly pulling up.
Matt
Old 10-12-2009, 03:42 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
I used to be able to get the 11S onto the center stand by just pushing on the foot tab... that was with the shorter Torque arm, though...
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 10-12-2009, 03:45 PM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
You're a leadfoot I hear.
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 10-12-2009, 04:01 PM
signit98's Avatar
LOL... who snitched?
Old 10-12-2009, 05:06 PM
It's really hard to put it on the center stand wearing flip-flops.
Old 10-12-2009, 05:28 PM
Registered Agitator
sgoodwin's Avatar
Longer shocks such as Ohlins or sport shocks also make it easier to put on centerstand (even with flops), not to mention handling improvements.
Old 10-12-2009, 08:11 PM
