Lennie's Sprockets
Can anyone point me to a video of the installation of Rocket Sprockets.
I'm sure I have seen one somewhere. Thanks in advance if you can help. |
In the mean time, here's his web site :
https://www.boxer-performance.com/sprocket-install-guides.html
2004 R1100S |
Enthusiast
It's really not that bad. The directions are pretty easy to follow. Just go slow and methodically.
The hardest part of the job is to loosen the sprocket bolt. Everything else is just following carefully the instructions.
R1100S / VIN ZA84895 |
I wanna Live 'til I die!
I've done quite a few of them and it really isn't that bad.
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 |
Jobs now done and there is a noticeable change in the engines behaviour for the better.
Yes - I remember when I did mine. It's a different bike after.
2020 R1250RS 2014 Ducati Monster 1200S 2005 R1100S BCR 1996 K1100RS 1984 Kawasaki GPz 1100 |
if you read the instructions and take your time and do one side at a time it is quite straight forward.
the result just makes the bike more fun to ride. enjoy all
Lennie www.boxer-performance.com 1998 R1100S Yellow is the best (now departed from my life) |
I see you
I remember having serious palpitations when the sprocket bolt let go with a CRACK! that sounded like thunder.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Yes, When you hear that sound on the first bolt, you wonder if you haven't just broken it... Much less stress for the second one.
Jersey Boy In Texas
Kenmoore, can you please describe the change you're seeing in the how the engine behaves? It must be significant if it turns the R1100S into a "different bike", as Jay K. stated. Is your bike otherwise stock?
' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' '' ' ' ' John Filak Dallas, Texas |
The change is that the bike has more grunt down low and will pull a taller gear. It appears to respond better to mild.throttle inputs.The.bike has a Remus exhaust , decat, electronic Kjet and upgraded injectors. It had a K&N filter however I replaced that with a standard one. All around a much more.tractable bike. Appears to run smoother with less vibration. That could be because I did the plugs, valves and throttle body sync.
I would highly recommend Lennie's Rocket sprockets. Fuel economy is better as well! |
the whole idea of the Rocket Sprockets is to apply cam timing changes to the BMW.
I tested the advancing of the cam timing 3 degrees at a time on the dyno and stopped at 9 degrees. What this does is open and close the valves earlier lower the torque peak by 800 to 1,000 rpms depending on the model. This means that the torque is moved to a more useable range and you can shift at lower rpms and not need to downshift on the highway. I hope you all enjoy the way they liven up the BMW to make them more fun to ride.
Lennie www.boxer-performance.com 1998 R1100S Yellow is the best (now departed from my life) Last edited by lennie; 09-09-2022 at 03:57 PM.. |
Hi Lennie. I enjoyed your sprockets on my previous S very much and I may purchase a set for my new one one day or another...
Been Nowhere Done Nothing
So really if your using the higher RPM range it wouldn't be advisable?
05 R1100S BCR, 04 R1150R 16 S1000XR, 24 S1000RR, 21 Ducati 950S |
Registered Agitator
Pretty much, I've always used my S that way. Back in the day there were many arguments against them by those of us who like the top end power, All my power is up top & revving it out is so much fun in the twisties. I've got a 12GS for low grunt work.
Buzz,
When I did back to back dyno tests, I lost 1.8 rwhp on the dyno with the Rocket Sprockets so not sure you will notice when you are revving to the redline. You can get that back if you grind the internal welds in the header pipes at the head end and the rear. I used to run 4,000 to 8,000 rpms in 4th gear on the open roads here in Australia and had lots of torque accelaratiing out of corners.
Lennie www.boxer-performance.com 1998 R1100S Yellow is the best (now departed from my life) Last edited by lennie; 09-11-2022 at 02:19 PM.. |
Jersey Boy In Texas
Thanks, Kenmoore!
Jersey Boy In Texas
lennie, thanks for the details. I found the website, and read through everything.
' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' ' '' ' ' ' John Filak Dallas, Texas Last edited by njsax; 09-15-2022 at 09:06 AM.. |
