Stupid valve stem question
This is very elementary dear Watson, but I'm going to be changing tires on the R11S soon, and I was wondering if the valve stems are standard size, or do I need to look for something special? The current plan is to just run up to the local auto parts store and pick some up when I get ready to do the tires. I hate to get half way into the job and find out that I need to order something special and have to wait another 3-4 days to finish. I'd rather just order them with the tires if needed. Thanks!
Matt |
Same as everything I believe....cars, motorcycles small trailers. I think it the only thing the world has agreed on collectively.
Lane
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi |
Dont taunt happy fun ball
Valve stems?
Huh? Are you inquiring about adjusting your existing valves? |
Just kidding ![]() Matt |
Are you changing them because they leak, dry rot or what?
Do yourself a favour and remove the rubber valve stems, then get the correct metal ones .
I bought a used road race bike years ago and the rubber valve stems were stuck at a 30 degree angle from the centrifugal force. I think it was lucky they did not crack on the guy. Since then.....I always install metal ones. They should be available at any auto parts stores. You can even install 90 degree ones if you have limited space to get a tire guage on the valve. Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat |
Well, I'm putting a new set of tires on so I figured that while I have the tires off, it would probably be a good idea to put some new valve stems in. They are cheap and I'll have easy access when the tire is off the wheel. I've had these things rot and leak before on cars - probably a REALLY bad idea on a motorcycle. Might as well try to avoid it if I can figure out what size they are. Sort of a "Why the hell not?" kinda situation I suppose. I have no idea how old the ones I have are now, and I'd rather not pull the same tire off of a wheel twice because I didn't install a new $2.00 piece of rubber.
Matt Last edited by moze229; 03-28-2010 at 07:17 PM.. Reason: lost quote |
Matt |
I believe there are only 2 sizes available......one is about 1/2 inch diameter.....and the larger is 5/8 diameter.....I am just going by memory here........and the old memory is not too good any more......anyhow.......what you need is easy to find as the BMW uses a standard tire valve.
Cheers
'09 BMW R1200R |
Lane
Believe it or not I've seen these vary too. Mostly with aftermarket 90 degree stems. Sometimes they are longer. I've been changing a bunch of tires lately for other people and also switching to a 90 degree stem for many of the Ducati folks. Some of these are hard to get a hose to when trying to fill it back up.
![]() If it's a stock stem there should be no problem.
'09 BMW R1200R |
Registered Agitator
They're standard size, the place that changes my tires replaces them on me every time they swap tires. Didn't realize it until I noticed my metal ones had been replaced. They say it's to insure no leaks from old stems.
