R1100S final drive oil level??
I seem to be a bit confused. Has the recommended final drive oil level for a r1100s been reduced by 50cc? Or, should we be going to the bottom thread?
Thanks! And if you have a link or picture to a service bulletin that would be great.
2008 HP2S Sport Touring 2009 525 Beta RR North Vancouver |
I see you
I have no official reference for you. I have always filled to just a hair below the bottom thread. 60k miles and no FD failures.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
I think it has been debunked that BMW has mysteriously lowered the capacity and that the lower level helps preserve the final drive. In any event, fill it until it reaches the threads on the hole, whatever capacity that results in.
- Mark |
Dont taunt happy fun ball
Man it's flat out here!
I rotate the rear wheel a few times after the first top off - then let it settle - usually goes down a smidgen then top it off again.
Here's the manual: ![]()
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD |
Thank you very much. To the bottom thread it is.
- Mark |
Snob Pirate
I remember reading that BMW changed the R1200S rear drive oil fill spec downward but then that wasn't the question.
geo
"She sips nitro... with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the ***** is born to run!" Barry, MFP mechanic BMW/Yamaha/Suzuki I've been ionized, but I'm OK now. |
BMWSuperBikes.com • View topic - final drive & brake fluid The ball is in your court. |
To put this in perspective, BMW recently changed the specified fill level of new style FDs from 220ml to 180ml. The affected bikes would include the R1200S, R1200R, R1200GS, K1200s...basically the new style FDs.
Older style FDs, which will include the R1100S, should still be filled as advised above. The (alleged) reasoning behind lessening the fill level is to hopefully reduce FD rear seal failure due to quefage. |
Snob Pirate
Yes, but because there are BMW empty fill and changing fill specs for the new drives and some enterprising BMW techs who think 200 is best because its in the middle, one should read the following thread to get an idea of what the current thinking is for the new ones.
FD Fluid Came Out Black at 3900 Miles. Another Dealer Screw Up? - BMW MOA geo
The measurement will be effected by how long you let it drain as well. Bottom of the threads is as well a bit subjective as the threads run well below what the plug needs. The allowance was to my understanding to prevent seal failure from expanding oil. I change it every other oil change, sometimes every. High shear zone. I also use 90-140 in the diff. Comes out nice and red every time.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci 2007 Ducati 999S Team USA , 2005 BMW BCR R1100S 2001 Boxster S w/tip |
