? About Emissions Canister on R1200S
Please don't call Al Gore on me, but am I going to run into engine performance issues if I remove the emissions canister that blocks access to the front shock? Making adjustments would be so much easier if it were removed. If anyone has removed it, could you let me know which vacuum lines need to be plugged/vented to atmosphere or re-routed so as not to freak out the ECU. Thanks.
Initials & assault rifle
F**k Al Gore.
Let's help a brother out-did you search the forum for any posts on the subject? I know there are numerous ones about removing the R1100S canister but I don't recall any on the R12S.
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER 1982 CBX | OLD SCHOOL 1969 H1 | QUESTIONABLE SANITY |
IIRC there is one hose from tank to a valve with electrical connect, that's a vent, anything down stream can be removed for adjusting the shock. I left the vent hose open, the electrical valve wired but nothing plugged,
tom rides and runs but 4 wheels no more; added a '94 DR350SE goes to Mendocino, F650Dakar captain america sees Baja R12S Red and Silver for cruising, the very first one was Honda C-90 way back when |
No try, do or not do
i pulled the solenoid as well, its all pretty straight forward if you look it over. I ended up using the tubing connector at the headstock and one of the longer hose pieces to complete the routing. 10 goes to the left throttle body 11 is the overflow hose routed to the swingarm and 12/13/14 goes to the tank fill neck overflow, Hook 12 to 11, and hook the solenoid end of 10 to the other throttle body. everything else you can take off, simple
2017 R1200GSW Rallye Shreddr Signature Model Last edited by shreddr; 08-21-2009 at 03:13 PM.. |
What about eliminating 10 all together and just getting another fitting cover like on the right throttle body?
you can do that too, but i didn't have the plugs, so i just connected the 2 intake ports with the one piece of tubing.
2017 R1200GSW Rallye Shreddr Signature Model |
Just the info I needed. Shreddr, thanks for the diagram...pictures always help mechanically challenged person such as myself.
Is there any change in performance by doing this or is it strictly for better access to the front shock?
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Rather than Tab A into Slot A instructions, just reason out what you're doing. You want to vent the tank to atmosphere rather than the canister, and you want to block off the intake spigots so they're not getting fumes from the canister. Everything else (canister, solenoid valve, hoses, etc.) goes bye-bye.
- Mark |
How's that for self-delusion! This is Al F***ing Gore: ![]() This is Al F***ing Gore in my dreams: ![]()
I just pour all vehicle fluids down my drain and litter every chance I get. But I do wonder about the perf. benefits of removing my canister. I'm already running with no cat.
Remove at will and rejoice in sticking it to Al.
Snob Pirate
Pelican Parts: Outlaw Biker Forum. Next thing you know the History Channel will interviewing everybody.
![]() geo
"She sips nitro... with Phase 4 heads! 600 horsepower through the wheels! She's meanness set to music and the ***** is born to run!" Barry, MFP mechanic BMW/Yamaha/Suzuki I've been ionized, but I'm OK now. |
Hey. Give algore credit for picking a scam that could require 500-1000 years to validate or invalidate.
We'll never know.
tm (R12, R11, R1) + 00 then S, S, /7 |
Contentious by nature
'07 R1200S '11 S1000RR '83 Suz 1100e (2) "The garage, is no place for a car" NRA Lifer |
By the way, have you ever seen the Al F***ing Gore Doomsday clock-he said about 3 1/2 years ago that the world had ten years before the use of fossil fuels would result in irreversable damage that would threaten the existence of the planet-6 1/2 years to go ![]() http://motls.blogspot.com/2004/10/al-gores-doomsday-countdown.html
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER 1982 CBX | OLD SCHOOL 1969 H1 | QUESTIONABLE SANITY Last edited by cageyar; 08-22-2009 at 11:32 AM.. |
Hey Shreddr,
How much bodywork did you remove to re-plumb? Thanks-
Mike '07 BMW R1200S '99 Ducati 996 '09 Husky TE450 |
i think i did it without pulling any of the body panels, but if you pull the side panles and tank center strip it would be very easy to get to everything.
