My R1200S will hit the rev limiter in top gear and has done it several times.
Straight flat road generally in the 40's F OAT. No wind about 7,800 ft elevation.
Dean O Copperhill,Tn Founder, San Jose BMW www.motorcyclistcafe.com www.sjbmwracing.com |
No try, do or not do
YOWZA
how are you getting a 107mm bore? There must not be much liner left? 161HP seems pretty competitive!
2017 R1200GSW Rallye Shreddr Signature Model |
There's a lot going on over in Germany!! the only way of finding out is going,this is just the tip of iceberg.
http://www.boxertrix.com/phpBB2/viewtopic.php?t=17508 |
Frank, can the series clutch withstand the higher power, or do you need to upgrade that as well.
Sometimes, when wound out in 3rd and power shifting to 4th I get the feeling I am overpowering the clutch as the revs will rise too quickly and I back off. This has happened a few times but I can't seem to reproduce it. I wonder if I am just spinning the tire?
the clutches make no problems. only the fat cat anti-hopping clutches like the more torque not.
Jeff, here in germany we have now for the Hp2s Boxer Burner. Last edited by fralind; 05-28-2013 at 11:42 AM.. |
