Private Citizen
AZ-Twin's Avatar
Oil Analysis
Any of you guys ever have an oil analysis done? Here is a report from some oil I ran in my G650, this oil was in the bike for my trip up the CDR.
If the viscosity drops again on the next batch I send them, and the aluminum content is still high, I might switch from Mobil1 to something else.
I plan to have one done on my R1200S next change too, just for fun, and post it here. If you have an oil report you want to share, post it up.
Rob Swartzwelder llllllllllllllll 97 M900, 07 R1200s(sold), 07 G650X Challenge, 99 BMW R1100S
(Brad Z on CF Dampeners)"it's the perfect blend of sophistication and bling."
(Roger A on moderation) "
Note to thin-skins and panty-bunchers - please note smiley."
Old 10-18-2011, 07:37 PM
Ghost Spoiler
chewie's Avatar
Rob how much does it cost and do they give your bike a room with some bike porn in it to make things, ahem, easier?
Old 10-19-2011, 02:00 AM
Edministrator
Steve Carlton's Avatar
Personally, I prefer MV Augusta brochures. Don't ask me why, but my bike goes for the Piaggio newsletter.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 10-19-2011, 04:40 AM
A single sample is just a point picture in time. Without trend information a point solution or decision from a single data point is misleading.
Do you have a base sample to compare it too?
Also, bike engines shed aluminum practically their whole life. The fact that a certain amount of aluminum is present could be cause for action but without a history its almost meaningless.
As for the oil to hold grade, that is another discussion as well. When an oil is graded, it is from a test sample that is representative of a batch. This number could easily be +/- 10% and still be considered in grade. Again, a comparison to a new sample of the same lot is a must.
For future samples, always submit two samples. One of new oil from the bottle and then one from the used sample.
Also, it is VERY easy to contaminate a sample from outside sources. Just by not having a hermetically sealed container could contaminate the sample even before the oil is put into it. Plus sample technique is EVERYTHING to consistent, believable results.
Old 10-19-2011, 06:21 AM
Private Citizen
AZ-Twin's Avatar
LOL,
25 bucks for the test, no bike porn. I just bring up one of Jeff's threads and that takes care of it.
Old 10-19-2011, 06:36 AM
Private Citizen
AZ-Twin's Avatar
Don,
I agree with everything you say. I am just fooling around here and sending a sample of new oil for analysis with each sample would get a little pricy. My hope is Mobil puts out a consistent product, and the folks at Blackstone have good data for that product.
I gather the sample per the Blackstone procedure, and I will do it consistently, so there should be no problem there.
My plan is to do analysis on this bike, my Toyota truck (holds 7qts of 5w20) and the R1200s.
After two or three tests on the G650, If the results are consistent with this test, I might run some different oil through it just to see if there is a difference.
Again, I am just playing here, I am sure any name brand motor oil will provide adequate protection, but instead of relying on all the stuff on the net, I wanted to gather some knowledge for myself. For the costs of the test in addition to what I pay for the oil I currently use, I could buy exotic oil, but I still would not know if I was paying for anything besides a sexy bottle.
Old 10-19-2011, 07:14 AM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/262083-yet-another-oil-analysis-rotella-t.html#post2518641
I did the viscosity test the first time around. After establishing a baseline, you don't really need to do it unless the engine goes through a different 'routing' between engine oil changes.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 10-19-2011, 10:24 AM
RBMann's Avatar
I was thinking this is a good indicator that fall is here then I remembered that you live in AZ.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 108K+ -sold
* '17 Africa Twin-totaled* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 10-19-2011, 10:40 AM
Rob, is the Mobil 1 that you're using a m/c specific variety, or is it the auto version?
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 10-20-2011, 10:46 AM
SergioK's Avatar
I was using the automobile version.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 10-20-2011, 11:38 AM
Private Citizen
AZ-Twin's Avatar
Auto version, 15-50 from the Wal Mart Jug.
Some Data.
Old 10-20-2011, 12:52 PM
Private Citizen
AZ-Twin's Avatar
I sent my oil in to Blackstone. I thought for sure that the oil was pretty much done, especially after being in there for over 8 months. I'm pretty happy with the results but I'm sure it came out so good because of the 2.3l of makeup oil I added during all this time. Seems like my S doesn't like the daily commute and she ends up eating oil like crazy.
Here is Sergio's Report.
Old 10-20-2011, 12:56 PM
those numbers for Zn and Ph don't look bad (tho not as good as their m/c specific variety), as do Sergio's oil analysis results.
Old 10-20-2011, 03:18 PM
AZ Pete's Avatar
Thanks for posting your analysis, I've thought about sending them a sample from time to time. What oil change interval are you using on your Tundra?
Old 10-27-2011, 01:18 PM
Private Citizen
AZ-Twin's Avatar
Pete,
Sorry it took me so long to get back to you on this but I wanted to wait till my test results came back.
Normally I change it around 6K, but the oil still looks surprisingly good, so I decided to run it a bit longer and have it analyzed.
This is the first test I have had done on my Tundra oil. I am going to run the oil in it now for 10K and see what they say. I will need to add some oil, usually I see it is down at 6K but I am changing it so I don't add any. I am around 6K now on the change I did in October, I have taken two long trips on this oil.
Here is the report.
Old 11-16-2011, 04:57 PM
Private Citizen
AZ-Twin's Avatar
I am now at 47044 so the oil in the truck has just under 6K on it, and it still looks good, and is not down a bit according to the marks on my ever so accurate dip stick. 5K of that is Interstate mileage.
Old 11-16-2011, 05:55 PM
AZ Pete's Avatar
Thanks Robert, I have been using the 0W20 in my Tundra and changing every 5,000 miles. I think that I will send a sample in this time to see what they say.
I am still using dino oil in the BMW, and will consider changing to synthetic next change, just need to see what the consumption is between changes. I've only had the R1100S for about 1,000 miles, so don't know how the oil consumption will be, yet.
Old 11-18-2011, 04:51 PM
