Replace front Frame-neck
Hello,
Steering column snapped off from the neck, after a sliding fall on black ice. Could this bit get welded or, have it replaced? |
nope.
replace it. |
What Brad says X 2
Expensive little piece..... |
Not when you consider a new one cost 830.00. tjs
Would a neck from a different model fit this, at all ? There are 1100R necks available on eBay, less dear to these.
Don't know the condition, but it's cheaper:
edit: Nevermind. Not all the photos were loading on my phone. This neck doesn't look so good. |
1. ask here (usually someone knows) 2. compare part numbers 3. sit 'em side by side. the one i see for sale is probably less than $200 with shipping and fondling. if it hasn't been tweaked, seems like it'd be worth the coinage. i don't think i'd ever be comfortable riding with a patched-up one. |
The R1100S is unique and special...which means the upper frame piece is unique to this bike. Buy a used one on ebay and get your bike back together and on the road again.
Damn, I wish I could follow that advise. |
if you get stuck for one I might have one with a broken fairing tab otherwise good
Have you tried beemerboneyard.com ?
black ice? and you're ok? you're one lucky fella!
Agree with flatbutt. Also how is the rest of the bike?
I'm quite alright, just few bruises easy enough for the elastoplasts.
Oddly, it wasn't a particularly cold night. Apparently, there was a broken pipe or something causing a water stream to become the adversary. Worst bit was to get the bike back on from the lay. Riding shoes are utterly useless in such a situation. Far too slippery than I'd imagined. Well, off to get this fixed over the holidays. Thanks for asking though. |
beemerboneyard.com doesn't have 46512331387 on stock..on some list, at the moment.
It's been 7,166 miles since I hit the Deer that broke it off last year (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/709681-personally-found-out-why-wisconsin-ranks-7-deer-hits.html), a trip to the Texas MotoGP is in there too. Glad I had it welded and saved my money. |
| All times are GMT -8. The time now is 07:04 PM. |
