99 R11S Can't Bleed Front Caliper
Having difficulty bleeding the front right caliper (haven't tried the left yet). I've moved the gas tank and bled at the ABS with no obvious issue, but I can't get any fluid out down at the bleeder on the front right caliper. This is with both a mityvac and pumping the brake lever. Anyone know what might be preventing brake fluid from getting to the caliper?
Brake hose may be collapsed if it still has original brake hoses.
Thanks, wswartzwel. The hoses are original, AFAIK. Might that also explain why I can't get fluid to flow out of the back brake line with the mityvac (i.e., I had to pump with the brake lever to get fluid out)?
Good thing it happened at home instead of locking up the caliper 500 miles away. http://forums.pelicanparts.com/suppo...eys/hiding.gif
When my K bike lines failed, the caliper would clamp, and then the release was slow. Like if you were rolling and nudged the front brake, the nose dropped, and tool a few feet before it came back up.
Were you having problems before? or just bleeding brakes to flush it? |
The right caliper is the one without a bleeder screw, correct?
I just ordered some stainless braided replacement lines. I vaguely recall a recall on this bike for the brake lines years ago, and don't think I acted on that. |
Not any more. |
What SS lines are you guys planning to use? I did Spiegler on my K bike and was impressed.
DSTJohn,
I'd bet you have OEM brake line crud clogging the caliper. That's what I had last winter, caused my front brake to lock down, acted as a check valve inside the caliper passages. I disassembled and thoroughly cleaned the calipers passages (both sides). That' the ONLY way you can clear the passages. Stupid simple, four bolts and one O-ring. I replaced ALL the hydraulic lines with Spiegler. Much better than Galfer, just because of the tools they provide. All the pics are here: https://photos.app.goo.gl/vdJIe8VNu17u4Z9N2 This was the problem: https://lh3.googleusercontent.com/YK...5-h613-no?.jpg |
You might want to blow out the calipers to see if there's debris in them before trying to bleed the system. It'll save a bunch of time & hassle if they are clogged.
dstjohn,
I seriously doubt the new lines will solve the problem. Also, you cannot clear the caliper passages with compressed air thru the bleed nipple hole to the brake line hole; they are connected directly together. All you'll clear is the 1/2" long hole between them. The passages and the cylinders are "dead ends". While you have the system drained for the line replacement is the perfect time to clear the calipers. They are stupid-simple: 4 bolts and an O-ring. Then you have easy access to clean and check the passages and pistons. See disassembled calipers here: https://photos.app.goo.gl/vdJIe8VNu17u4Z9N2 |
I've never had to replace them in many pad changes over the years. Just turn the pins so they're easy to pluck out with a pair of needle nose pliers. I always clean off the pins & springs holding the pads every time I change pads & spray the pucks & seals with brake cleaner before reassembly.
Dave - if this is what you have on your front right caliper, you'll need to replace the strange barrel shaped thing on top of the caliper with a bleed nipple.
That fitting is for the assembly line filling of the front brake hydraulic system. It unscrews and a bleed nipple then goes in. Save yourself some mess and carefully tape the threads of the bleed nipple with plumbers tape. That will prevent the threads from weeping and bubbles from entering while you are bleeding or pumping the system. DOT4 eats paint and plastic. Keep a wet rag handy. And drop a quarter (25¢ piece) in the handlebar reservoir to keep it from squirting on the dash and windscreen. Clutch side, too. That's the best 50 cents I ever spent on the bike. They're still in there. https://lh3.googleusercontent.com/5v...3-h911-no?.jpg |
| All times are GMT -8. The time now is 06:33 AM. |
