Fpalbrecht
Heated gear/Acc port
I have a 2004 r1100s with accessory port(picture below). I would like to plug my Gerbing, 12v heated gear into this port. What size fuse is associated with this plug? I added up my heated gear per gerbing instructions and came up with 10.3 amps if I use everything I have. Gloves, insoles, jacket liner.
I always heard 1.5 times the amp.
My 04's power port has a 10 amp fuse in the line. You could just put a 12 in there if it came to it, the wire run is short. If it blows , shut off a shoe
Fpalbrecht
Thanks.
