What does it mean when....
Air blows out of oil fill tube (as it runs) on 01 Boxster S. I mean a lot of air, bad oil separator ??
Old 01-20-2019, 06:36 PM
Typically with a failing AOS you would get suction at the oil fill tube. I got this response from another forum member after posing your question to another forum: "Likely due to combustion pressure leaking past the piston rings, if not a plugged crankcase ventilation system AOS. A compression check (dry and wet) is recommended." Another member posted: "A positive pressure at the oil filler tube would seem indicate a high pressure in the crankcase." Hope this helps.
Old 01-22-2019, 10:26 AM
https://forums.pelicanparts.com/boxster-cayman-forum/999842-my-aos-failure-symptoms.html
Old 01-22-2019, 10:42 AM
Administrator
Dmitry at Pelican Parts's Avatar
Some more info in addition to the ottobon100 provided:
https://www.pelicanparts.com/techarticles/Boxster_Tech/09-ENGINE-Air_Oil_Separator/09-ENGINE-Air_Oil_Separator.htm
Old 01-22-2019, 11:48 AM
