-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   2002 3.2 engine swap - auto into manual car (http://forums.pelicanparts.com/showthread.php?t=1022112)
klickdavis 02-26-2019 10:57 AM
Hi All,
Was unable to find on forum
I have a 2002 3.2 S and need to replace. Car is manual.
Is an 3.2 from a automatic a straight swap using my engine harness?
Any other issues to consider with the swap?
thanks
Rick
BYprodriver 02-27-2019 08:48 AM
Originally Posted by klickdavis (Post 10369847)
Hi All,
thanks
Rick
Yes the engines are the same, I have a upgraded rebuilt engine for sale if you want to increase power.
klickdavis 02-27-2019 12:50 PM
Thanks for offer. Budget gets me a used engine.
BTW... if you don't mind, will a 3.2 from 2000 or 2001 go in without modification??
Rick
BYprodriver 02-27-2019 01:00 PM
Rick
Yes, 2000,2001 & 2002 are nearly identical.
Brian in Tucson 03-01-2019 11:58 AM
Are you doing the swap yourself? I did mine last winter and it was quite an adventure. You want a replacement engine 00 to 02. I went the opposite direction, put a manual in my automatic car. It requires swapping the complete engine harness and capping off a vacuum line--the automatic uses a vacuum operated water valve.
You get it all apart and look at that jungle of wiring sitting on the garage floor and it sinks in "What have I gotten myself in to?" It's a puzzle but you can visualize where things go. The secret on the harness is to make sure you have no spare connectors when you're done.
It's a learning experience--what took me a couple of weeks to do, I could probably get done in just a few (3 or 4) days.
