2000 Boxster S Roof Wont Open
Yesterday my 2000 Boxster S soft top would not open. I had the car parked, ignition on, parking break set { parking break indicator light on). When I opened the roof latch the windows dropped. When I depressed the switch to open the roof nothing happened and there was no sound of a clicking relay or any other sounds. Any Ideas?
Check the fuse first.
Sent from my SM-N950U using Tapatalk |
I visually inspected the 30 amp fuse in D3 location and it looked in tact
I just went an reinspected the instrument cluster and realized that the parking breaak warning light is not illuminating when the break is set.
Try resetting the e-brake? Otherwise sounds like it's time to get a new brake switch.
Brian Lamberts Tucson AZ |
it's most likely the microswitch in the top latch. I replaced mine and the top works fine now. Same symptoms as yours.
https://www.pelicanparts.com/catalog/SuperCat/1043/POR_1043_ELSWCH_pg2.htm#item5
2002 Porsche 911 turbo 2007 Porsche Cayman S track car 1987 Porsche 924 Carrera GT tribute 2015 BMW X5 |
