Engine swap. 2001 to 2004 2.7
Hello guys! New here.
I have a 2004 Boxster Base 2.7 manual with the M96.23 engine. Ah the good ol IMS bearing decided to go and skip timing. I got a hold of a 2001 2.7 M96.22 engine fully dressed with harness, accessories, maf, etc...with only 45K miles. I noticed that the valve cover is shaped differently and the sensor for the cam timing is in a diff place. Doing more research i see there is a pretty good diff in between these 2 engines as far as cam chains, DME etc.. Question: What would it take to install this engine (2001 M96.22) in to my 2004 which had the M96.23? What do I need to modify, replace, purchase, or transfer? Think you again for your time. Added pics for flavor! http://forums.pelicanparts.com/uploa...1553792299.jpg http://forums.pelicanparts.com/uploa...1553792299.jpg http://forums.pelicanparts.com/uploa...1553792299.jpg http://forums.pelicanparts.com/uploa...1553792299.jpg |
This is going to be a nightmare; the 2004 engine is VarioCam+ and makes extensive use of CAN bus technology to communicate with sensors, the early engine is VarioCam only and uses different communications protocols; the engines use entirely different DME's (7.2 vs 7.8), etc. You need to find a later engine, or be prepared to Frankenstein the entire car.....
stephers Comments: I have a 2003 2.7 Boxster that has blown out the IMS bearing and the only altertanive engine is a 2.7 2000 engine. I have completed the update, put a new clutch in and installed everything into the car but I am getting one trouble code that I cannot get rid of. P0349 is the code " cam position sensor 2-open circuit " I have checked all the wiring and actual rotor, all is OK.. What can I do to fix this. A newer engine right now is just not an option where I am. Followup from the Pelican Staff: Have you confirmed the signal it present at the DME? Since this a circuit code it is pretty cut and dry. Tee DME expects to see a certain amount of voltage at the Camshaft sensor wiring and does not. I would suggest: working at the DME, KOEO (key on egine OFF) backprobe camshaft sensor 1 and see what you have for voltage on all 3 wires. Should be something like, 5 volts, 0.1 volts and 5 or 0.1 on the other (depending on shutter position). Then compare those values with the sensor that is giving you the problem. Use this test to track down what wire(s) is open or shorted. - Nick at Pelican Parts Reference: https://www.pelicanparts.com/techarticles/Boxster_Tech/11-ENGINE-911_Engine_Swap/11-ENGINE-911_Engine_Swap.htm The above gives me some hope considering he swapped his 2003 to a 2000 lol. |
Yup. It would be easier to put an 04 3.2 in than to try to get the 2001 to work in your 04. Sorry fellah.
I have a great running 2003 2.7 with 53k for $3000+shipping. Don't try and putting a 5 chain motor in a 3 chain car. It's not worth the headaches.
I am curious what's the progress now?
I wonder what he's selling the 2001 engine for,..
Update: Talked to the guy I bought the engine from. I am eating the cost of shipping it back to him and he is willing to swap it for the one I need. No longer selling. Shipped it out yesterday. I appreciate all the input. |
Sent from my SM-N950U using Tapatalk |
| All times are GMT -8. The time now is 03:59 PM. |
