Cool clutch feel
just upgraded, from 97, to a 2005 base boxster. clutch, pressure plate and flywheel done 6000 miles ago. i find the 05 to feel very light on the initial pedal travel compared to the 97. normal or not.
Old 06-04-2020, 03:09 AM
I’ve just changed my 3.2. 02yr and I find the pedal extremely heavy. I changed all 3 bits plus the helper spring
Old 06-04-2020, 09:55 AM
Originally Posted by Blue99 View Post
Iíve just changed my 3.2. 02yr and I find the pedal extremely heavy. I changed all 3 bits plus the helper spring
Must not have used OE parts. if you do the clutch feels very soft & gets stiffer when it wears.
Old 06-05-2020, 10:59 AM
Had it changed by an independent- am very disappointed as the original clutch was not slipping but was heavy when I bought the car so when I had a leak at the rear seal I decided to have the clutch changed at same time.
It’s lost my business that’s for sure.
Wish I’d done it myself now
Old 06-08-2020, 12:57 AM
Did you change the hose to the slave cylinder? They swell on the inside and make pedal effort more heavy. All external DIY but access is tight.
Old 06-08-2020, 02:52 AM
Hummm interesting point. Something I’ll look into
Old 06-08-2020, 06:42 AM
