Help. reversed battery connection to open the bonnet
Hi,
A battery in my Cayman 987.1 (2007) was dead, therefore, I tried to open a bonnet through battery connector in fuse box for replacing a battery.
I tried it several times with another battery or battery charger, but no luck.
And then, I misoperated. I connected it with reversed + and -.
After that, everything have not worked, such as door rump.
Does anyone know how to recover it?
I checked all fuses in the fuse box but all fuses are not disconnected.
Is there possible to broken the relay in the fuse box?
Thanks in advance,
Eiji
Old 05-06-2020, 12:58 AM
JFP in PA's Avatar
Polarity reversals are known to burn up quite a few electronic modules in these cars, you now need to flatbed the car to someone that knows what they are doing..............
Accrochez-vous bien de vos rêves..........."
Old 05-07-2020, 03:33 PM
I reversed the polarity on my 2006 Cayman S. Did you horn start honking and the window washers start spraying? I had to replace the main fuse, replace the fuse in my radio, and replace the alternator.
Old 05-12-2020, 01:52 PM
It'll be legen-waitforit
stealthn's Avatar
JFP I assume you are serious, so which modules usually go? Do I need a PIWIS to go through every system? I accidentally touch the post putting in a new battery...
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 06-23-2020, 07:14 PM
JFP in PA's Avatar
Depends upon the vehicle model and year, but we have seen everything from the alternator, Litronics headlight controls, PASM/PSM, PCM, to the comfort control system, the immobilizer, and even the DME cooked when this happens. A lot seems to depend upon what was switched on inside the car when the event occurs.
As a lot of these control modules need to be coded to the car, yes, a PIWIS is required, even if it is just to reset some of the systems. Sometimes most of the damage is blown fuses, but there is a lot of electronic stuff in modern cars that really does not like reversed polarity.
Old 06-24-2020, 06:02 AM
stealthn's Avatar
Thanks!
It's a 2006 Cayman S, so a little less computers than today. I will check it today to see if the smell is gone (could be alternator) and check the charging. It did fire up right away, but I want to make sure nothing is damaged.
Bob James
18 Macan GTS
Old 06-24-2020, 08:33 AM
stealthn's Avatar
Just changed the alternator; what a ***** of a job! Tight space.
On a positive note my Antigravity battery worked!, twice - battery was completely dead, press the button, and she fired right up.
Bob James
18 Macan GTS
Old 07-10-2020, 11:49 AM
