Retired, finally
SiberianDVM's Avatar
986 front control arm link bushing
Has anyone ever successfully replaced the rubber bushing on the front control arm link with a polyurethane one? I can't find anyone who markets one or any other kind of replacement bushings, only high priced replacement units.
I will try pressing out the old rubber bushing and see if Energy Suspension has a correct sized generic bushing.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 01-25-2021, 12:35 PM
Powerflex should be able to help out https://www.powerflexusa.com/
Old 01-26-2021, 07:31 PM
Retired, finally
Thanks, but already checked there, and they don't market this one.
Old 01-27-2021, 05:17 AM
I had assumed you were looking for callout #3 on their 986 page. Is that not the case?
Old 01-27-2021, 07:12 AM
Retired, finally
#3 is for the control arm. I am replacing all 4 since the ball joints are all toast and they are non-replaceable. The front control arm link is this one
https://www.pelicanparts.com/More_Info/99634104306.htm?pn=996-341-043-06-M155&SVSVSI=1042&DID=19444
Old 01-27-2021, 10:05 AM
Ah. Now I see it. Oh, well.
Old 01-27-2021, 02:52 PM
Retired, finally
Yep, just my luck.
Old 01-27-2021, 07:56 PM
Sorry, little confused. Which bushing are you wanting ?? What I did on mine was bought 4 new control arms with new ball joints. The bushings that are on the inner end of the arm i left rubber, the bushing that is close to the ball joint I replaced with Poly. My thinking is i stayed with rubber for vertical movement so it wasn't hard as a rock, but used Poly for anything that held the arm from moving horizontally. Vertex has some arms and links with Poly already installed and I used those everywhere I could. Switched over to coil overs and have been very happy with the new tighter feel.
Old 02-04-2021, 12:47 AM
Retired, finally
Thanks for the info. For now I just replaced the control arms, tie rod ends, drop links, and struts, as they were all shot.
Old 02-04-2021, 06:01 AM
