-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   DME question (http://forums.pelicanparts.com/showthread.php?t=1071863)
Stl_986 08-31-2020 06:15 PM
DME question
Is there any difference between the dme for a manual vs one for a tiptronic? p/n are the same. Reason for asking is cause I need a new immobilizer and my car has symptoms of being bad per common issues listed by ecu doctors. Finding ecu, key & immobilizer all over for 2.7 manual cars but none for a tiptronic. Prices are cheaper then having mine repaired it looks like.
Imagine it's just programming differences between the base & S as well. If so I will just pull the trigger and have it towed to the shop for programming.
JFP in PA 09-01-2020 07:57 AM
Yes. The DME for the Tip expects to see data from the Tip controller and will throw codes if it does not.
