trying to piece back this 06 Cayman need help
http://forums.pelicanparts.com/uploa...1657583610.jpg
/\ /\ /\ /\ Can someone please tell me what this 10 pin black connector goes too?? Im trying to put this 06 CS back together, It appears some kind of control box or something?? Need help!! Headlights dont work so I'm thinking something is missing but I cant find anything in the parts pdf http://forums.pelicanparts.com/uploa...1657583835.jpg On driver side I am assuming the circled plug goes to the drivers side radiator TIA guys |
It looks very similar to the plug of the temperature sensor:
https://www.pelicanparts.com/More_Info/99660641000.htm?pn=996-606-410-00-OEM&KeepHeader=Y -Matt |
That is something I am unsure of. I just have recognized that connector on other German cars. I can tell you that the OEM number is 99660641000. I did a google search of it and found a few diagrams but they are vague however they might be enough for you to connect the dots.
Hopefully this helps! -Matt |
Thanks Matt,
The p.o. removed the stock adjustable shocks and my thought is that plug went there. I installed a center radiator, and now am waiting for the second radiator to show up. http://forums.pelicanparts.com/uploa...1657763554.jpg Next I have to move the radiator forward 1" (Thanks Vwloosenuts) Install front crashbar. Get drivers side High beam and turn signal functioning. Install cross pipes and then get the system refilled and bled. Make a few brackets to secure the pandem rockers and flares. Get the front bumper wrapped to match the car Finally clear a go to dealer message which is weird cause when I scan the car it says there are no stored or pending codes???http://forums.pelicanparts.com/uploa...1657764040.jpg |
getting there. :D
| All times are GMT -8. The time now is 05:59 AM. |
