Anyone with a cayman pandem kit installed
I could use a little advice on your radiator setup.
Did you need to modify anything to get the front bumper installed?
What size wheel did you run? Offsets?
TIA
Old 07-04-2022, 06:28 AM
TIA
Hey
You need to move both radiators forward a minimum of 1". I welded new tabs on mine to move them forward. I am running 19" wheels and I believe you will need to do this with 18s also.
The front wheel spec is a 19x10 with a -12 offset if I did it again I would go -9 the -12 is fine just
The rear wheel spec is 19x12 with a -50 offset. if I did it again I would go -65 but works with the -50 absolutely fine just visually personal preference would be the -65 as I added a 15mm spacer on my -50s.
These are without the 15mm spacer on the rear.
Jeremy Brooks AKA VWLOOSENUTS
***My cars are built to meet my approval, not yours!! My money, my cars, my happiness.
Old 07-13-2022, 08:10 AM
Originally Posted by VWLoosenuts View Post
Hey
Hey thanks so much. I'm having to install radiators so I guess there's another thing to do. I have the center radiator installed now so hopefully that 1" doesn't hurt.
Again thanks
Old 07-13-2022, 10:26 AM
Banned
this car is a beauty
Old 07-19-2022, 06:21 AM
