Oil lever check
I think I am missing one of the manuals for my 09 Boxster.....
How do I check the oil level?
Foolproof underestimates the dedication of fools |
Turn your key one click to light up the dash. The oil gauge will start checking level and give you a reading. Don't confuse full with all bars lighting up. The top bar means 'over filled'. Do this check after the engine oil is warm and has been shut off for about 30 minutes.
Tony G 2000 Boxster S Last edited by tonythetarga; 12-10-2017 at 06:56 AM.. |
Tony G 2000 Boxster S |
On my 2010 Boxster S, the procedure is in the Owners manual under the "Instruments, On-Board Computer, Warnings" section. Odd place to locate it....
Engine running at idle, engine warmed up, car sitting level, wait for it to time out on its test. Top bar lit = oil OK, DON't add. Only bottom bar lit = add oil NOW. In between, add some soon. Good luck. |
a follow up question, My 2000 s oil gauge has read one bar down for awhile, today in 95 degree heat it reads only three bars up from bottom ,then stayed on longer than usual. any worries?
i will check it again after it sits in the garage awhile
1999 Carrera2 tip arena red 2000 Boxster S tip...arena red ....black 1981 911sc targa...grey mkt.import...Rosewood 1978 911SC, guards red sunroof delete .much missed 73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead. |
No.
Accrochez-vous bien de vos rêves..........." |
Thats oretty succint....thanks?
so, today oil gauge read one bar down from top.
I will be getting an oil change in the next few days.
got oil changed, shop filled it by using the dipstick to guide them
now after mild overheaing and followed by white smoke out.Car is diagnosed with needing head gasket.coolant is in oil.I am frustrated with how long it took to get this diagnosis.This has been both dependable and fun in my two years ownership.Will need to sell it very soon. it has 75000 miles and is tiptronic.
Probability is
not a head gasket but caused by a crack in the head. Or in the expansion tank.
https://sites.google.com/site/mikefocke2/what-can-you-do-if-your-engine-is-blown |
I know what you're thinking, "where the hell's the dip stick?" In the 987, there is no dipstick. I know that in the 987.1 non-S cars, it's possible to backdate a dipstick. In the Boxster S with the 3.4L there is no place to put a dipstick at all.
Get the engine up to operating temp. Turn the motor off, but leave the key "on". In the "information center" you'll see a countdown clock. Usually it's 5 mins if you JUST shut the motor off. If you get home and shut the motor off and then go inside for a bit and then come back out 10-15 mins later, the countdown may only be a few seconds. If you don't get the car warm first, the countdown may be a lot longer than 5 mins.
Intermixes are generally from a cracked head. That happens when the engine is overheated. I’d wait on buying a gasket.
i am waiting on the final diagnosis.The car is at a well known shop that does Euro import cars.very busy, so a long wait.NOt sure what the answer is or the cost yet.
the shop gave up, car sat for two weeks,Im sending to a Porsche certified guy, on Friday.
NUTs..at least its rained here a lot so I wouldn't be top down anyway
Darn. Sorry to hear that. 😫
its tough to find a shop in a new area,is like trial and error.But the next one was recommended by a call to a shop here who said their Porsche guy had retired.I am hopeful for someone with a little more skill and knowledge.Well see...Meanwhile the car is in my garage until the 13th.
