Scouting a Boxster
I'm in the market for a used Boxster. I'm looking at older models and found a beautiful 2005 base model that I just looked at. A couple of questions:
Is it typical for Boxsters of this era to have a little orange peel in the paint? It has a clean carfax and I could find no sign of a repair but at a certain angle you can see a little orange peel. What is the recommended oil change interval when using a synthetic (Mobil 1)? Thanks! |
They do have a slight orange peel to the paint which is visible at certain angles.
Oil change intervals are every 10,000 miles or 1 year whichever comes first, full synthetic only. Personally I would change earlier than 10k miles. Things to watch out for, IMS bearing, bore scoring and the usual maintenance type items like water pump, brakes, etc. |
The IMS bearing in the ‘05’s may not be serviceable. Try sticking to 986 models. The ‘05 is the crossover year to 987’s.
Whoa....
IS there a way to tell from the VIN if you have the type that cannot be serviced?
No way to tell by VIN. you open up the trap door and look. Personally,
I’d avoid an ‘05. I know two that have failed with no track use. |
Tony I owe you a beer. I was this close...
Sent from my SM-S908U using Tapatalk |
Because you don’t have to tear down the engine. I know the larger bearing is replaceable. I said non- serviceable. That means replace like the 97-‘04 models.
And, I did say ‘May not’ as it was a crossover year. https://forums.pelicanparts.com/boxster-cayman-forum/1141256-scouting-boxster.html |
Besides, who would spend 20k to rebuild a motor to replace the IMS when you can buy a nice 2000-2004 Boxster with an LN bearing already in for $12-$15k?
Hi, I have a 2002 986 S Guards Red, Black Interior with red accents, black roof (manual), motor taken out to save weight, has 18" x 8.5 boxster II wheels all round, black, with Yokohama Advans, Bilstein PSS9s, I'm about to put it up for sale, but currently having new trailing arms put on. If your interested I can send you more info.
Thanks to Tony and all of you for the informative responses. I think this thread will be very useful to others in the future.
So, if you find a really nice 2005 with low miles do you go for it even though the type of IMS in it is unknown? I was hoping to just change it when it came time for a new clutch. The one thing that really bothers me is the 10k oil service interval. The owner of this car followed that schedule. It does not appear he read the "or one year" part. |
"*Model year 2000 and 2001 engines came from the factory with either a dual row or a single row bearing IMS. Some late model year 2005 engines were also fitted with a larger bearing that is not serviceable without a complete teardown of the engine. It is impossible to verify what bearing is needed by VIN or engine number. Visual inspection is the only reliable method to determine which type of bearing is needed in these engines." |
I find it hard to believe that Porsche does not have internal records of what bearing went into what 2005 car. |
| All times are GMT -8. The time now is 04:14 PM. |
