My '97 Boxster (2nd Owner) @ 60,000 miles about every 4th start attempt requires 10-15 key attempts before starter engages AND/OR the key (a new one) is jammed in the ignition key cylinder - apparemtly a "typical" problem.
How do I correctly identify the actual part (order #) for BOTH a) the electrical portion of the ignition switch and b) the ignition key cylinder? Too, is a NEW key required if a new key cylinder is installed? How do I obtain one, if needed? THX! Doug Stowell, Greenville, SC |
It sounds like ignition switch is bad. The electrical part not the mechanical part. Fairly inexpensive.
Sent from my SM-S908U using Tapatalk |
Agreed.I might spray contact cleaner in there, let it dry out and try it then. I like CRC it doesnr affect plastic parts
1999 Carrera2 tip arena red 2000 Boxster S tip...arena red ....black 1981 911sc targa...grey mkt.import...Rosewood 1978 911SC, guards red sunroof delete .much missed 73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead. |
