'15 Boxster Xenon PDLS headlight replacement
Can I install the headlight myself and feel confident that the PDLS system will work properly? Or...does the P. 'dealer' have to re-program the system? Removal/re-install looks straight forward...Saw suggestion to disconnect the battery first...
'89 911 Carrera Coupe '25th Anniversary Special Edition' '15 Boxster "Mighty Mouse" |
If you are replacing a like for like item it should work fine. If it doesn't then you know that it has to go to the dealer or find a local Porsche friend with PIWIS.
Sent from my SM-S908U using Tapatalk |
Thanks Neil...Found a shop in NJ, that will replace just the lens. Which is really my issue. It's deeply pitted and crazed...will not polish out ...any thoughts on this?
