-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   The Best Headers for the 987.2? (http://forums.pelicanparts.com/showthread.php?t=1148325)
Fabspeed Motorsport 10-25-2023 06:05 AM
These modular headers are the perfect solution for any Cayman or Boxster. Our patented RENNKRAFT™ modular design features a quick release V-band connector that allows the owner to easily swap between our German made HJS 200 cell cats and a cat bypass “straight pipes” for track use. RENNKRAFT™, translated from German is “race power”. These unique headers offer true street and racetrack functionality in an innovative precision engineered package.
SOUND:
Equipped with our 200 cell cats, you will get a louder exhaust note with a much more raw sound. Higher frequency tones are more defined, and off throttle burbles are more robust and transparent. With the cat bypass pipes installed, you're in store for a sound much more akin to a 911 CUP car than a Porsche street car. The volume isn't overbearing, but the sound is very aggressive and race bred. It totally changes the character of the car.
FEATURES:
  • Fits all Porsche 987.2 Boxster / Cayman vehicles worldwide 2009-2012. Including Cayman R and Boxster Spyder.
  • Constructed from CNC mandrel-bent T304L stainless steel
  • Impressive power and performance gains
  • Save 2 lbs / 0.9 KGs with Sport Cats and 7 lbs / 3.2 KGs with Cat Bypass compared to the factory headers
  • Modular design that uses a V-band clamp so one can quickly swap between cats and cat bypass
  • With the RENNKRAFT™ system, you can quickly install our QUICKTRACK™ cat bypass pipes for Racing and all out Race track-only competition events
  • The RENNKRAFT™ system has been awarded a US Patent and is the only system of its kind in the world
  • Switching to cat-bypass for track events prevents catalytic converter degradation during all out competition racing abuse
  • F1 style high velocity merge collectors
  • Designed from 3D scans of the OEM headers so we can achieve perfect bolt-on fitment
  • We use German-made HJS HD tri-metallic 200-cell EURO 6 homologated catalytic converters for the best performance and reliability
  • We use the largest catalytic converters that will fit in the factory location for maximum flow
  • Flows 93% of a 2.5 in straight pipe
  • Optimized for maximum performance with NO catalyst generated check engine light, guaranteed, when Sport Cats are installed
  • No ECU tune required
  • Will fit with any brand of aftermarket exhaust system designed to work with the factory headers
  • 25+ years of air-cooled and water-cooled Porsche experience went into our design for these hand-crafted headers
  • Simple DIY (Do-It-Yourself) bolt-on installation, no cutting or welding required
  • All Fabspeed performance products are backed by the Fabspeed Lifetime Warranty
http://forums.pelicanparts.com/uploa...1698242691.jpg
JFP in PA 10-25-2023 02:04 PM
For $3,700 to $4,500, they dammed well better be.................
tcora 10-26-2023 02:46 AM
SOUND:
FEATURES:
Would you care to quantify “impressive”?
2.7RS 10-26-2023 01:42 PM
Still made in China?
