-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   Air Oil Separator Install Problem (http://forums.pelicanparts.com/showthread.php?t=1154283)
bhayman 01-21-2024 01:01 PM
I bought a new AOS from Pelican for my 1999 Boxster base, and the part arrived just fine. The problem I'm having is that I cannot for the life of me get the 2 bolt holes on it to line up properly on the install so I can bolt the new one in. Other issue is that it seems the "nipple" on the new AOS that slides into the engine block hole at the bottom is slightly larger than the old one that came out, and does not seem to want to slide into the hole much at all. Any ideas on how to solve these issues? Thanks in advance.
CarGuyNeil 01-21-2024 01:28 PM
Did you compare the new and old part to make sure they match and didn't send you the wrong part?
Sent from my SM-S908U using Tapatalk
JFP in PA 01-21-2024 02:28 PM
Is it a factory part or aftermarket? Willing to bet it is the latter………..
CarGuyNeil 01-21-2024 02:35 PM
Good point, the tolerances could be the difference. They always say to buy the Porsche-branded AOS. Don't skimp on this part.
bhayman 01-22-2024 08:07 AM
Yes, I compared the parts and they look identical to me except for the nipple that goes into the engine block. As I mentioned, it appears slightly larger than the old one. Thanks for your input.
bhayman 01-22-2024 08:08 AM
It's an aftermarket part. I guess I probably should have purchased an OEM one?
bhayman 01-22-2024 08:09 AM
I think you're probably correct here. I am going to go ahead and purchase an OEM part and see if that helps. Hopefully Pelican will take back the aftermarket one I bought. Thank you for your input, appreciate it.
