roof stuck open
2003 porsche986 s
50000miles
Hardly used,Not been used for a year.
its happened Twice now, when opening roof ,and then when i try to close it wont close, but will still go down more but not up.Also i notice passenger window would only go 3/4 of the way up.i locked it up,Then 10 minutes later i opened it and tried the roof again and lucky it closed.Tried window opens normally now roof closed.
Anyone any idea to scared to open it again.
Old 02-06-2025, 08:52 AM
HI
After a bit of investigating. I took top latch to bits and i assume as mine is the later one it only as one micro switch in, I think.? Which drops the windows.
What i have got now is the windows drop the top goes down but not up . Some times it goes up but not often .But i can bypass relay and get the top to go up.
Now does the top micro switch just drop windows or does it also do up and down on roof.Thanks
Old 02-12-2025, 01:22 AM
I think you're certainly on the right track with a bad microswitch. There are numerous microswitches in the 981, yours is probably the same. I would suggest doing a search for an electrical diagram for your car.
Old 02-17-2025, 02:06 PM
