throttle jitter
My 987.1 Cayman S 3.4l has some jitter in the power delivery in 6th gear. When I try to apply a little more throttle the engine will surge a bit. It also surges a bit when I lift off the throttle a little. It is most noticeable in 6th gear. I have cleaned the throttle plate and MAF. Is there somewhere else that could be sticking?
Clutch slippage?
Sent from my SM-S938U using Tapatalk |
I think it is in the fuel or intake system. It isn't an rpm change, it is more of a power surge. Are there some air valves that could be sticking?
Maybe a sticking or dirty Vacuum Unit with Air Intake Tube
https://www.pelicanparts.com/More_Info/99611012053.htm?pn=996-110-120-53-OEM&SVSVSI=815&DID=249621 |
Intake ishh
| All times are GMT -8. The time now is 04:47 AM. |
