Questions on Alarm System
Been thru a bunch of threads on the alarm system - Driving a 99 that the alarm keeps going off.
From the threads I have learned - Please correct me if this is incorrect.
To shut off the alarm you double click the key fob door lock button - Horn will beep and marker lights will come on solid for about 2 seconds
If one presses the key fob to lock just once and the horn goes off this is signalling one of the alarm switches has not been satisfied.
What I find happens - Mainly every time I lock the car I will get a horn signal (pressing key fob) only once. This is telling me something is not set - If I hit the key fob to lock and the horn does not go off anywhere from 1/2 to 2 hrs later the alarm will start sounding.
I believe what this is telling me is one of the switches has opened or closed indicating to the car a breach of the alarm system and setting it off.
So what I want to know - do I have the key fob button pressing sequence correct - Press once to lock - no horn beep - all is set with the alarm
Press once to lock - Horn beeps - something has not set in the alarm system.
Press twice to lock - Alarm disabled.
I do not know which of the switches has failed is usually open - I have manually made sure the roof latch switch is all the way in - Does anyone know why when pressing in the switch for the soft top latch it clicks 2 time - once at about 1/4 of the way in and once at 3/4 of the way in?
Made sure the center council is good - both by checking lid is closed properly and manually tripping the switch -
Have pushed down on the frunk and trunk lids
I suspect it may be in a door lock or the radio ground - The car has an aftermarket stereo.
Going to take into Porsche and have them diagnose - If it is from the stereo I will have the installer take a look. Hopefully they do it for free.
If it is a different switch I may take it on myself or just let them do it.
Does anyone have a list of all the alarm switches in a 99?
Old 03-01-2016, 07:36 PM
Local Mad Scientist
Andy911sc's Avatar
Having this same issue on my fathers 2001 Boxster S. Any follow-up to this?
1982 Porsche 911sc
2009 Jeep Grand Cherokee Laredo X
CPA-PCA Member Since 2012
Old 07-22-2025, 10:42 AM
