what kind of AT fluid does a 97 trip take?
howdy all !
i drained AT pan on my 97 boxster then went to dealer to get fluid for it WOW $$$$$ 325 $$$ for 20 liters (order only) of atf all i need is 3.5 . so i called around the other dealer can order it by the liter but its $45, but he said that audi atf is the same and its only $20 /liter and in stock ... so i called around some more and someone told me "any dextron III synthetic atf will work fine" so mobil 1 atf is only $7 /quart ???
any thoughts?
thanks
chuck
Old 07-06-2005, 03:20 PM
AFJuvat's Avatar
http://forums.pelicanparts.com/showthread.php?threadid=148819&highlight=transmission+fluid
I posted this some time ago. The Porsche dealership told me that any tranny that suffers failure and has the incorrect fluid will have voided its warranty.
Will regular old ATF work - probably, will it cause long term damage, I don't know, as a shop, am I willing to risk it with my customers cars? - hell no.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-06-2005, 04:26 PM
thanks for the info i did a search but that did not come up .
this car is under no warranty thats for darn sure but $320 for 1 gallon of fluid if all it is is dextron III thats a shame.
any other inputs?
thanks
chuck
Old 07-06-2005, 10:49 PM
update at 12:38 am my time.....
http://www.pzlqs.com/Tech/Pdsheet/QuakerState/Gear&Transmission/Pdf/MultiVehicleAutomaticTransmissionFluid.pdf
quaker state claims "multi vehicle ATF" is a replacement for the porsche fluid
here it is in german and it lists Esso LT 71141 fluid by name
http://www.taligentx.com/passat/maintenance/atfchange/quakerstateatf.pdf
i will call mobil 1 and talk to them today and see if there multi vehicle is a replacement also.
AFJuvat thanks for the "Esso LT 71141" link
chuck
Old 07-06-2005, 11:56 PM
The fluid from Porsche is not $320 a gallon. Usually 4 litres will fill correctly. The problem is Porsche only sell it as a 20 litre container.
Might be cheaper to have an independent shop change it.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 07-09-2005, 02:48 PM
well here is how it ended ... i drained about 6 liters and after looking at the audi and vw info i called shell oil (1800bestoil) there tech said that quaker state and pennzoil "multi vehicle ATF" would work great! even mixing the fluids so thats what i did. it is written on the bottle that its good for porsche. i will let yall know if it turns bad. by the way the fluid that came out seemed in need of change kind of burnt.
i think its all relative ... for 1 liter of atf... porsche $45, audi $20, vw $15, mobil 1 $8, pennzoil $3.56.
from what i can tell the first 3 are all the same product for the ZF trannys, and the next 2 are just more advanced products that can do more things. but what do i know i'm a pilot.
as the price of boxsters comes down there will be more of this type of info coming out.
have fun good luck
chuck
Old 07-09-2005, 06:23 PM
Just a item from a forum for one of those "other" cars.
http://bimmer.roadfly.com/bmw/forums/e32/forum.php?postid=4761800&page=1
Old 07-10-2005, 10:20 PM
