boxster tires
Does anyone know if a 275/35/18 will fit on the rear of a boxster?
Brian
Old 04-30-2005, 01:57 PM
I have an old list from last year and 265/35/18 is approved. The difference between 275 and 265 is not much.
Old 04-30-2005, 02:38 PM
It is? Approved by who? That is mildly surprising. The issue there isn't the width but the sidewall height. Porsche uses 265/40/18 in the rear. However, in going with a 35, you've decreased the diameter and circumference of the wheel. As such, I'd suspect a small deviation/inaccuracy in your speedometer. The question is the level of inaccuracy in the speedo. Bottom line, a 265/35 is not the correct size tire for the 18" wheel. Does anyone disagree?
Now to the orginal question, will a 275/35 work? The tire size in question will no doubt fit. I've never seen that size used/recommened (that doesn't necessarily mean anything). I'm guessing it will work out correctly, although I guess I'd have to do the calculation to be sure (too lazy right now). I'm guessing it's not a real common tire size (I could be wrong).
J-RAD
2006 Boxster S
2000 Boxster S
1982 911 SC Euro
Old 05-02-2005, 08:35 AM
Approved by Porsche. It is a 10 page bulletin given to the dealers. It is called Summer Tire and Wheel Summary, dated March 26, 2004.
For 18" rear tires 265/35/18 is listed. For the front it is 225/40/18. These same sizes are listed in the 2000 Boxster owner's manual.
Where are you getting a 40 profile for the rear 18"?
Old 05-02-2005, 10:32 AM
Where are you getting a 40 profile for the rear 18"? [/B]
Correction: I'm an idiot...ignore everything I say. The 40 is for the fronts. Is it Monday already?!?
J-RAD
2006 Boxster S
2000 Boxster S
1982 911 SC Euro
Old 05-02-2005, 11:01 AM
