| carlson |
02-19-2008 10:58 PM |
ignition switch assembly replacement
Does anyone have information on replacing the ignition switch assembly with the updated one (housing & switch) for the earlier Boxsters. I've seen the links or threads on replacing just the switch, but was wondering what was involved in replacing the entire assembly. I'm concerned about having future problems if I just replace the switch on my 98 as it seems many people have had to replace the switch multiple times if the entire updated assembly isn't installed. For the past few years, I have to manually turn the key back to the run position after starting (it doesn't return by itself) or the accessories - radio, climate control, etc, do not function. I'm concerned that if I replace just the switch I may end up with worse problems if the replacement fails. To replace the assembly, does the steering wheel or column have to come off, or is it all done from under the dash?
