Boxter cabin air filter
The car is a 2004 basic boxter. The owner's manual says there is a cabin air filter. I have looked several places, the mechanic said it is up in the front battery area, not there. Does anyone know where the cabin air filter is? Thanks Lynn
lynn, 68 912 coupe, 2011 Cayman base |
Cabin Air Filter is located under the front hood. Remove the battery cover and then remove the plastic cover on the left side of bat. - it is the cover from the left of battery to the edge of fender, there are to claws which hold the cover at back of cover - lift up from front of cover You can see the filter located under the dash remove brackets and change filter. All direction are from standing at front of Box. This is for a 2005 Yours may be the same.
fbfarm, many thanks. I just did not look deep/or left enough. Lynn
