ASD ASD is offline
ASD's Avatar
What happened?
Poated this but cant find it.my 986blost substantial coolant on Monday..we added more after it cooled....then lost it again.Towed to a shop here, very reluable and honest guys Ive used for years.they could not find a leak..kept it 4 days, pressure tested drove it in 90 plus degrees and no leak still.i picked it up drove home no leak. Showed 180 on the gauge but red light was flashing. wtf? If it does it again i
Dont know what to do.the shop didnt charge me..the nearest grtman car specialist is 40 minutes drive.could it be crackbin lower coolant reservoir?
Sent from my SM-G991U1 using Tapatalk
1999 Carrera2 tip arena red
2000 Boxster S tip...arena red ....black
1981 911sc targa...grey mkt.import...Rosewood
1978 911SC, guards red sunroof delete .much missed
73 914 2.0 found in a bunch of cardboard boxes, and brought back from the dead.
Old 07-08-2022, 12:58 PM
Gauge light flashing means you are low on coolant. Pull back the trunk carpet and check the coolant tank hoses. That is where mine leaked.
Old 07-08-2022, 03:03 PM
ASD ASD is offline
ASD's Avatar
ok thanks....
Old 07-10-2022, 07:13 AM
ASD ASD is offline
ASD's Avatar
still no diagnosis, and no further leakage.I took the car into a not so near shop that does imports mainly German.Certified techs are Porsche trained and own a few too.They found a leaky aos and say my cv boots will need replacement.All else was ok, pressure tested, no leaks.Still no answer for the original problem, but the car seems fine and I will drive it and keep an eye on the temp.
Old 07-20-2022, 05:24 AM
Check overflow cap.
They are known to fail.
Went for a group drive one car puked lots of coolant after a long uphill grade.
You would of sworn it was a major leak.
We got some water to fill it up.
He found his cap was loose.
Didn't have any problems rest of trip.
Hope yours is something simple.
Bernie
Old 07-20-2022, 06:31 AM
And make sure the cap is the latest version.
Old 07-20-2022, 09:51 AM
ASD ASD is offline
ASD's Avatar
Thanks will do.
Old 07-23-2022, 08:44 AM
ASD ASD is offline
ASD's Avatar
Got a new cap last year,but I can't say it's the newest version.
Old 07-23-2022, 08:45 AM
JFP in PA's Avatar
Look at the cap, the number stamped on it should end “-04” if it is the latest cap.
Accrochez-vous bien de vos rêves..........."
Old 07-23-2022, 09:32 AM
ASD ASD is offline
ASD's Avatar
I ordered the Latest from our host.
Old 07-25-2022, 02:10 PM
ASD ASD is offline
ASD's Avatar
I got my cap from Pelican....its black, but has the latest number, evidently oem for Porsche, while blue is factory part.should be ok......
Old 07-27-2022, 02:58 PM
JFP in PA's Avatar
Don't bet on it, your "host" has played very fast and loose with the what the term "OEM" actually means for years, which is why we don't do business with them
Old 07-27-2022, 03:00 PM
ASD ASD is offline
ASD's Avatar
I got that,happy its working at this point
Old 07-30-2022, 11:22 AM
