Fuse replacement kit?
:D
anyone knows the website link for purchasing fuse kit for 2002 boxster s? having gone through Pelican but not sure which one is.:D thx sites I have found.. Pelican Parts.com - Fuses Pelican Parts.com - Plug in Fuses Pelican Parts.com - A.T.O. Mini Fuses Pelican Parts.com - Maxi/Mini Fuses Pelican Parts - Product Information: FUSE-BLT-KTN |
I'll have to check on this, oddly we don't have them listed in the Boxster section...
-Wayne |
:D
thx |
Wayne, do you know exact the fuse diagram for boxster s 2002?
Bentey manual says it's similar to 2001, but that'all it says, the book doesn't have diagram for 2002. I did an "emergency unlocking from luggage front compartment lid", and I found that there were few fuses missing... sadly, I didn't notice anything strange before. |
If everything is working fine, then I wouldn't worry about the missing fuses - they are probably for SAT nav, or heated seats, or something like that. -Wayne |
much appreciated. |
Here's what I came up with for part numbers for this fuse booklet:
986-610-217-00 (1997 thru VIN 98VS6 01006) 986-610-217-01 (1997 from VIN 98VS6 01007) 996-610-217-01 (1998-1999 same as above) 996-610-217-02 (2000) 996-610-217-03 (2001 - superseded to 996-610-217-04) 996-610-217-04 (2002) 996-610-217-05 (2003-2004) 997-610-195-07 (2005-2008 - all previous versions have been superseded to the -07 part number) If you wish to order one of these for your car (recommended), then simply punch the part number into our search engine located at the top of the screen. -Wayne |
Also, the appropriate Porsche part numbers for fuses are:
999-607-004-00 (5 amp) 999-607-083-00 (7.5 amp) 999-607-085-00 (15 amp) 999-607-087-00 (25 amp) 999-607-010-00 (30 amp) 996-610-214-00 fuse removal tool (seems to always to be missing). -Wayne |
Here's what one of the booklets looks like (found one while cleaning up tonight).
-Wayne http://forums.pelicanparts.com/uploa...1295854501.jpg |
but since your IMS retrofit product is going to be ready soon? (In Macth right?:cool:) I think I will purchase them within 1 package till then. |
IMS Kit will probably be available in March, but things are getting in the way of us doing more testing (we're swamped!).
-Wayne |
| All times are GMT -8. The time now is 06:56 AM. |
