hucqym (guest)
Guest
Posts: n/a
so if I want HID for both low and high beams, do I need two kits? or is a smarter configuration possible on a 2001 boxster? bi-xenon?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Budget Boxster HID Headlamp Retrofit - 986 / 987
Old 03-25-2011, 11:01 PM
Author of "101 Projects"
Wayne 962's Avatar
Yes, you can wire up your high beams and low beams both with HIDs, but you will indeed need two kits then. If you're looking for the best setup, then I would probably recommend the factory Litronic setup from BOSCH. Although it also only has traditional high beams, the low beam performance is stellar.
- Wayne
