Guest
Posts: n/a
Wayne I have a 1997 boxster with a top that has seen better days I have a leak passenger rear where the top meets the body of car not sure what seals I require,the top has no power can I disconnect the fuse and operate manually,can I cut out plastic window and replace it with more plastic from the hardware store is there an appoxi type glue I can apply to the rip in my top???? any advise would be greatly welcomed thank you
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Convertible Top Repair - 986 / 987 |
Author of "101 Projects"
Yikes, lots of questions here. I'm going to copy this to the forums so that we can discuss it further there. In general, there aren't really many seals on the top itself that are replaceable (like the older cars). If your top has no power, then you have some issues there. You might want to consider bolting a hard top onto the car and driving it that way, as it may be easier and cheaper in the long run.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Gare
thank you Wayne, I m confused are the seals for the top not replaceable or do I have to buy a new frame, top, seals.
Sorry for the confusion, and welcome to the forums. Yes, there are replacement seals available for the convertible top. Not cheap, but they are available here: Porsche Boxster Seals & Weatherstripping - Page 1
Where is the roof leaking from? -Wayne
Gare
the roof
Hi the roof leaks at the rear right corner where the top meets with the cars body directly between there seems to be a space of about 6inches where the seals gaskets are cracked hope Im describing this right thanks to anyone with advise
Gare
looking at a fiberglass skin hard top for 800.00.looks just like the oem top I believe that comes with hardware; can the spin lock system be adapted or bolted on and oh can the oem hard top fit fit under the front or rear lids of my boxster:?? so many ??s any thoughts greatly appreciated .
Crazy Austrian http://www.ws-ab.com |
The big long seal that runs along the rear edge of the top is replaceable pretty easily, if that is the one that is leaking. The article on replacing the convertible top documents this replacement pretty well...
-Wayne
Gare
thank you for your time and insight
its just great to have access to your wealth of information thank you all.
