pasrt need it for clutch and ims
want to know if i have all parts need for job
is 02 boxster S , MY REAR FLYWHEEL SEAL NOT LEAKING , WILL BE SMART REPLACE IT? ANY SPECIAL TOOLS TO REPLACE AND INSTALL THAT SEAL?? -NEW CLUTCH KIT -NEW FLYWHEEL IMS BEARING KIT LN -NEW 8 BOLT FOR FLYWHEEL WHAT ELSE IS NEED? i SEE SOME PEOPLE REPALCEING CRANKCASE BOLTS? BUT IS THIS NECESSARY??? PART NUMBER WHY? |
Crazy Austrian http://www.ws-ab.com |
what is the part number for the tool to install RMS??? OR WHERE I CAN GET IT CHEAP? CAUSE WILL BE ONE JOB TOOL!
Inquisitive user
Hell, We could just pass it around and rent it from you one RMS change at a time. ![]() Randy
Perpetual change. It will happen!!! Last edited by randy_k; 04-16-2011 at 09:22 PM.. |
Author of "101 Projects"
Interesting, someone else just asked this same question yesterday. I have a list of all the parts needed for both jobs in my tech articles, which you can find here:
Clutch Replacement: Pelican Technical Article: Boxster Clutch Replacement - 986 / 987 Intermediate Shaft Bearing Replacement (IMS): Pelican Technical Article: Boxster Intermediate Shaft Bearing Replacement and Upgrade (IMS) - 986 Boxster (1997-04) - 987 Boxster (2005-06) -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
what is part number of tool need for install rear flywheel seal?
If you measure the seal properly, you can simply use some plastic PVC pipe cut into small pieces. Just make sure you get the proper depth for the seal.
-Wayne
