Author of "101 Projects"
Wayne 962's Avatar
Horn keeps going off...
Wayne, I called in to the company today inquiring about a specific project that might have been in the 101 Projects for the Boxster. I have a 2000 Boxster and the horn switch is finally failing. had to pull the fuse the other day. Is that a DIY project or need a dealer or experience mechanic?
thanks Walt Sweet Lake Arrowhead CA
Replacement of the horn switch / airbag frame is pretty easy. The problem is that the rubber inserts on the back of the frame fail, and then the horn begins to go off intermittently. This usually happens annoyingly when you're going over a bump. The steering wheel article covers this, you can find it here: Pelican Technical Article: Boxster Steering Wheel - 3-Spoke Wheel Upgrade - 986 / 987
-Wayne
Old 04-19-2011, 12:45 PM
