newlife
Hi, maybe a really, really dumb question but here goes....
When placing the car on the jack stands, should I always use 4 stands no matter what the project? In other words, have the car supported by all four jack stands ? When I do an oil change should I support the car with all four jack stands or will two suffice? Things like that. And is there some kind of sequence for taking the car off the jack stands? Thanks Rod |
I almost always just use two jackstands at a time - if I'm working on the front, I use two on the front, on the back, two on the back. I use two on the back for oil changes. About the only reason to do four would be if you need to check fluid levels while the car is in the air (like when changing transmission fluid), but I generally drop mine after draining the oil, but before adding oil, I so get a good measurement when the car is on the ground.
I tend to lower the car in the opposite order that I put it up - if I jack up the right side, then the left, I will let the left down first, then the right. It's probably not that big a deal, but that's what I do.
Steve Wilwerding 1998 3.4L Zenith Blue Boxster 2009 Meteor Gray Cayenne |
+1 on Steve's comments....unless I'm yanking all 4 wheels for maint or to scrub the rims I ONLY do 2 at a time and then since I'm scared LOL...I shove 1 tire under the body and I have the jack still on the car using my slit hockey puck ( to protect the unibody weld) in front of the nearest jack stand as an added back up...even with that it's still cramped underneath the darn thing but manageable.
+1 on using jack stands for either the front or rear depending on the job. I only use four if I'm working on both ends of the car or need it to be level while I'm working.
The part I find hard is getting the jack under the car to lift it up and still have space to stick in the jack stand - they both like to sit in the same general area.
1999 996 C2 sold - bought back - sold for more 1997 Boxster BSR POC/PCA #254 1978 911 SC Daily Driver Licensed DE/TT Instructor |
Author of "101 Projects"
Yup, you can use two in the front with the rear wheels on the ground, or two in the rear with the front wheels on the ground, or two on one side of the car if it's not jacked up too high.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Does putting just the rear on stands when performing an oil change make a considerable difference for how much oil drains out?
If I need rotate tires, e.g., rear-left to front-right, and I only two jack stands, what is the best practice to jack up the car?
You can't rotate tires on the Boxster, the wheels are staggered (different sizes front and rear) and the tyres are usually directional.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
newlife
Wow, great resource here Wayne. Thanks to everyone. Thanks for the book Wayne !!! btw.
Rod |
I guess I am an overachiever, if I use a jackstand I use all 4...LOL
