-   Boxster & Cayman Forum (http://forums.pelicanparts.com/forumdisplay.php?f=14)
-   -   Notchy shifting - which transmission fluid to use? (http://forums.pelicanparts.com/showthread.php?t=628522)
franco (guest) 09-06-2011 06:34 PM
In the morning my boxster shifts a little notch y.
After about 15 miles it shifts very smooth.
I am using Redline 70/90w
Should I change the gear oil to something else.
It has about 10k on it.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Oil Change
Wayne 962 09-06-2011 06:34 PM
I would try the Mobil-1 synthetic that I believe Porsche recommends. Everyone seems to have a different experience with transmission fluids, it's difficult to determine what is good for one person or another. Still, the synthetics seems to work well.
- Wayne
caymanStef 09-17-2011 04:27 PM
I use Pennzoil 75w90 gl5 ,smooth shifting it my track & week- end carSmileWavy
dghii 09-18-2011 09:33 PM
How old is your car? When did you last change your front motor mount? Shifting is much improved if you replace a worn mount.
