Guest
Posts: n/a
Great article, thanks.
Do Boxsters have high oil flow requirement that would not be met by a proper conventional oil filter used in conjunction with the filter adapter Pelican sells? Interested in purchasing, but do want to starve the engine and cause damage. __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Oil Change |
Author of "101 Projects"
I think the system used on the Boxster is not terribly good and installed there probably for ease of access and overall cost (as well as environmental concerns?). These screw-on adapters are very good and I run one in my car.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Do the screw on filters, with adapter, hang down lower than the OEM? Any clearance issues i.e. I've installed the ROW suspension and my Boxster is now almost an inch lower.
Platinum Member
The Napa 1042 filter is shorter, so it shouldn't be a problem. I also use an accusump adapter which lowers it even more, without issues.
-Wayne
I am no engineer but if you look at the size of the oil return pipe from the filter and the opening to the filter looks pretty high flow. I tried the spin on and the lifters took longer to get quiet.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci 2007 Ducati 999S Team USA , 2005 BMW BCR R1100S 2001 Boxster S w/tip |
